dozer Posted October 16, 2012 Report Share Posted October 16, 2012 Stock Cylinder, 4 mil .030 over, CPI inframes, 35 PWK's +2 timing, HJR Ported / HJR Domes .. 134 psi.. 91 pump gas.. $1200-1500 if you have a good set of pipes these numbers look fishy, was that at 99.7685849 % efficiency. whos dyno was this, it doesnt matter you did it wrong. was yo left foot in the air and right thumb up your azz? loaded or unloaded? it looks photoshoped either way. j/k looks like a nice build. Quote Link to comment Share on other sites More sharing options...
Colby Posted October 16, 2012 Report Share Posted October 16, 2012 ^^^ nice Colby. Who dyno'd that? Sandtraxx? yes sir.. Quote Link to comment Share on other sites More sharing options...
CJ PERFORMANCE Posted October 16, 2012 Report Share Posted October 16, 2012 theres a 4 mil crank brand new in the for sale section as of yesterday.. havent looked today Quote Link to comment Share on other sites More sharing options...
emtbanshee Posted October 16, 2012 Author Report Share Posted October 16, 2012 Ok so 4mil it is. It will prob take me through this winter to get this built since the wife and I are trying to have a baby and save some money. Ok next question is where do I start. What is the difference between a long rod 4 mil and a stock stroke 4 mil. What's the best application for my budget. Quote Link to comment Share on other sites More sharing options...
Colby Posted October 17, 2012 Report Share Posted October 17, 2012 (edited) Ok so 4mil it is. It will prob take me through this winter to get this built since the wife and I are trying to have a baby and save some money. Ok next question is where do I start. What is the difference between a long rod 4 mil and a stock stroke 4 mil. What's the best application for my budget. Long Rod refers to the longer rod length (115mm is the usual, 110mm is stock) , takes some stress of the rotating assembly due to the pistons being angled less so they dont want to push so hard against the cylinder. much better for high rpm reliability.. same price.. will have to run 795 series wisecos w/ a long rod.. i would highly suggest it Edited October 17, 2012 by Colby Quote Link to comment Share on other sites More sharing options...
MarineNYC Posted October 17, 2012 Report Share Posted October 17, 2012 I guess i exagerated too much when i said it will rape everybody... Ur a moron Quote Link to comment Share on other sites More sharing options...
dunesovertrails Posted October 17, 2012 Report Share Posted October 17, 2012 Ur a moron Sorry man just excited because my dad wants to do a 421 serval build on his bike this winter. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted October 17, 2012 Report Share Posted October 17, 2012 Like ^^^ said depends on budget... You could build a 421 serval and get raped by everybody in drags and be a beast in trails as long as your swingarm wasnt too long, Or you could go with a 4 mil which would be sick too fixed! Quote Link to comment Share on other sites More sharing options...
Nightmare Posted October 17, 2012 Report Share Posted October 17, 2012 I've seen drag ported 350's on alky rape 421's all day. 1000 bucks will build a nice lil monster. And I can still trail ride. Quote Link to comment Share on other sites More sharing options...
emtbanshee Posted October 18, 2012 Author Report Share Posted October 18, 2012 Ok so a little update. Got the motor torn apart and found etching on the piston that says 1.50mm. So is that a .60 over bore. Are the cylinders worth porting at this point. Quote Link to comment Share on other sites More sharing options...
Colby Posted October 18, 2012 Report Share Posted October 18, 2012 Ok so a little update. Got the motor torn apart and found etching on the piston that says 1.50mm. So is that a .60 over bore. Are the cylinders worth porting at this point. still got the rest of the bore your on and at least one more.. might as well go ahead with it.. I have a set of .030 unported cylinders and pistons ill sell for $225 shipped Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted October 18, 2012 Report Share Posted October 18, 2012 Port them and if you like them enough nikasil them when it finally goes. Yeah it is expensive, but if you don't wanna buy new cylinders and port those, and change the whole set up again..... Quote Link to comment Share on other sites More sharing options...
emtbanshee Posted October 19, 2012 Author Report Share Posted October 19, 2012 Sounds good. You can still see some cross hatching in the cylinders. Really getting pumped about this build. Prob gonna take all winter bit it will worth it. Quote Link to comment Share on other sites More sharing options...
Colby Posted October 19, 2012 Report Share Posted October 19, 2012 Sounds good. You can still see some cross hatching in the cylinders. Really getting pumped about this build. Prob gonna take all winter bit it will worth it. you will love the 4 mil ! Quote Link to comment Share on other sites More sharing options...
emtbanshee Posted October 19, 2012 Author Report Share Posted October 19, 2012 I found a 4 mil kit on eBay that comes with a hot rods crank all seals and gaskets and pistons for $629.00. Is that a good deal? A 4 mil crank at fast is $429 alone Quote Link to comment Share on other sites More sharing options...
