Cub cyl
the "cub" cylinders are 68mm in bore size.. the difference in size of motors are....
stock stroke 68mm - 392
4mil stroke 68mm - 421
7 mil stroke 68mm - 443
10mil stroke 68mm - 465
pretty much a ton of combinations, depends on the power your wanting, what your wanting to spend
wrong.. "most" cubs are 68. however you can get them in any size from 64 to 68.... For example I just sold a 66 bore cyld.
I'm thinking about getting some cub cyl and I found a set of cub cyl that are 398 or something like that. I thought that cubs started at 421. Can someone explane to me the differences in there cyl to me thanks.
398 is a 66 bore 58 stroke.
the cub he mentioned in his first post was referring to 68
must be seeing something Im not
So a stock strok 68mm 392. Is that a ok setup to be running. I have never heard of this most of them I hear of are 421.so if I wanted to in a year I could go with 4mil with this same cyl ....
gg
yes, but you have have to get the cylinders ported for the difference in 4 mil port timing
gg
no, the port heights on a stock stroke cub to a 4mm will be raised too high.... now if you spent a bunch of $ to get the cylinder welded up, reported and plated, along with some custom domes, different pistons and base gaskets you could run it but that would be the ass backwards way of going at it.
