Trail Tech Lights (3)
I have three trail tech lights that are in as close-to-new condition as you can get. One is still brand new in the box. I will be running my LED lights on my new build, and don't need these. I will include two stock position mounts, with two stainless allen head bolts to mount them. The pair of lights contain one 35w flood, and one 35w spot. The BNIB light is a 75w Spot.
$110 shipped for all 3.
One bulb is cracked, I'm assuming from not having it straight when the outer housing was threaded on. Bulbs are $8 each from Trail Tech, or RMATV.
I was thinking it would be cool to have the 2 35w ones in the stock locations wired to the low beam circuit and the single 75w one on the bars wired to the high beam circuit for panning the horizon. If you had a billet clamp with a key switch hole, you could mount it there with some washers.
110 with shipping to ontario canada n3h 4r6 should be pretty close to the same shipping rates as usa if you ship with usps
