trickedcarbine Posted October 12, 2012 Report Share Posted October 12, 2012 I know with some of the Mikuni carbs they have different configurations for a particular carb such as angled fuel nipples, air screw location, end even idle screw. Is it possible to find a 35mm PWK with a right hand idle adjuster and air screw? Maybe modify it and tig weld the old holes? I could have sworn that I have at least saw a kit for re tapping the idle screw on to the right side, can't find it anywhere. Thanks for any input Quote Link to comment Share on other sites More sharing options...
camatv Posted October 12, 2012 Report Share Posted October 12, 2012 call sudco ask them for a differnt body? i have had pwk's like that in the very long time ago past. also had both fuel lines inside so no pipe rubbing on fuel lines. Quote Link to comment Share on other sites More sharing options...
Paulie B Posted October 12, 2012 Report Share Posted October 12, 2012 I know with some of the Mikuni carbs they have different configurations for a particular carb such as angled fuel nipples, air screw location, end even idle screw. Is it possible to find a 35mm PWK with a right hand idle adjuster and air screw? Maybe modify it and tig weld the old holes? I could have sworn that I have at least saw a kit for re tapping the idle screw on to the right side, can't find it anywhere. Thanks for any input You would also need the right side slide to match correct? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted October 13, 2012 Report Share Posted October 13, 2012 call sudco ask them for a differnt body? i have had pwk's like that in the very long time ago past. also had both fuel lines inside so no pipe rubbing on fuel lines. That's awesome. Did you have to request them special or anything? I wasted all my gas on a line that burned up so that would be perfect. Quote Link to comment Share on other sites More sharing options...
