BansheeTeam Posted October 12, 2012 Report Share Posted October 12, 2012 Yoo Everyone so I'm starting to have a small problem again. First I checked both plugs was was surprised to see that both of them had different colors on them Both of the plugs had 2 colors on them. The first one looked pretty good to me it has a nice chocolate brown on one side but gets lighter on the other half side almost getting white with tannish effects. What could be causing this? The other plug had the same problem but with a different color. It was like dark brown but almost white on the other half side. When I pulled the plugs out they were wet and black on the ring but i dont run much oil, however thats fine i guess because often times i fill up in the gas station and pour oil directly into the tank so oil ratio differs but not by much. I make sure they dont smoke much they only do in the beginning but the oil im running burns clean and is good never had a problem with plugs and jetting until I started running pods. I checked the air screws and turns out the side that was running dark brown had a different turn out that the other. But i turned both of them in fully and turned them both 1.75 turns out cause that was the best it ideals at. So what should I do because the bogging is back i'm almost certain it's from the pod filters. When i clean them they run perfect the first day and all but after a couple of days maybe a week i get bogging again. I do run outerwears but this is kinda bothering me I guess i'll just lay it aside and re-install the airbox with a single k&n and run 280 mains. I'm currently running 300's 25 pilots and 3rd groove Dynojet needle. Should i throw a 30 pilot that i have if i jet to 280. Should i try 280 and 30 with the pods? Please help thanks again I'm trying to upload a picture but this fucker wont allow me to upload more than 50k so I dont have an other way to show you guy other than email, so leave you email in the reply and ill email them to you Elevation 0 sea level Temperature around 85 ish differs through the day and night Mods: VF3 Toomey T5's Pod Knn's +5.5 Timing Nothing else Getting a moose racing boost bottle soon I'll just throw it in. Quote Link to comment Share on other sites More sharing options...
