bike barter Posted October 12, 2012 Report Share Posted October 12, 2012 i just got a 1991 banshee of corse it needs more work then what i was told i have a lot of slack in my shifter up and down and in the shift rod back and forth when the bike is running i cant down shift shifts up just fine with alot of play tho but when its off it will down shift but i have to play with it for a little bit can any one help me what should i do Quote Link to comment Share on other sites More sharing options...
NYUK Posted October 12, 2012 Report Share Posted October 12, 2012 shift shaft and eccentric bolt adjuster are both wallered out. Quote Link to comment Share on other sites More sharing options...
Dunes98 Posted October 12, 2012 Report Share Posted October 12, 2012 Mine did the same thing when the eccentric bolt broke off. Pretty easy fix, just remove the clutch cover. You will see if its broke or not. Good luck. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 12, 2012 Report Share Posted October 12, 2012 Broken eccentric bolt. Quote Link to comment Share on other sites More sharing options...
bike barter Posted October 12, 2012 Author Report Share Posted October 12, 2012 Broken eccentric bolt. thanks man im going to rip it down now Quote Link to comment Share on other sites More sharing options...
bike barter Posted October 12, 2012 Author Report Share Posted October 12, 2012 thanks man im going to rip it down now i think i put the clutch on wrong i need help its all rev and no go Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 12, 2012 Report Share Posted October 12, 2012 i think i put the clutch on wrong i need help its all rev and no go I'll bet you didn't line up 1 of the arrows on the pressure plate with the dimple on the inner clutch hub. The pressure plate doesn't mesh with the inner hub properly and it ends up looking like this. Quote Link to comment Share on other sites More sharing options...
Finch Posted October 13, 2012 Report Share Posted October 13, 2012 hate it when i do that Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted October 13, 2012 Report Share Posted October 13, 2012 There's a link to my bottom end walkthrough in my signature. Check it out and you can see how the bottom end goes together. -Jared Quote Link to comment Share on other sites More sharing options...
bike barter Posted October 13, 2012 Author Report Share Posted October 13, 2012 I'll bet you didn't line up 1 of the arrows on the pressure plate with the dimple on the inner clutch hub. The pressure plate doesn't mesh with the inner hub properly and it ends up looking like this. i took it back apart the presher plate looks to be lined up when i pull the clutch lever in i can see olny the first 3-4 plates push out my clutch was working great untill i took it off to replace the the broken bolt for the shifter spring Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 13, 2012 Report Share Posted October 13, 2012 It's not rocket science. The springs push on the pressure plate. The pressure plate clamps the steels and fibers together and makes the bike go. Something is obviously holding the pressure plate away. The pressure plate can go 6 different ways. Only 3 will work. If that's not it, and you have free play at the lever, then you're just going to have to take it apart and see what you assembled wrong. You are using a torque wrench on the 6 pressure plate bols, right? Quote Link to comment Share on other sites More sharing options...
Finch Posted October 13, 2012 Report Share Posted October 13, 2012 You are using a torque wrench on the 6 pressure plate bols, right? whats that? Quote Link to comment Share on other sites More sharing options...
bike barter Posted October 14, 2012 Author Report Share Posted October 14, 2012 whats that? yeah i useds a torc wrench 7ft pounds and i dont have any play in the leaver when i pull the the clutch lever i can c the first 3 plates push out ?? Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 14, 2012 Report Share Posted October 14, 2012 As much as we would like to help you, only you can take it all back apart and find what you put together wrong. Make sure the clutch cable housing is properly in the end holders. Check the washer before and after the basket. Go back through the bottom end assembly walkthrough. Let us know what you find. Quote Link to comment Share on other sites More sharing options...
