banshee will not down shift
bike barter
i just got a 1991 banshee of corse it needs more work then what i was told
i have a lot of slack in my shifter up and down and in the shift rod back and forth when the bike is running i cant down shift shifts up just fine with alot of play tho but when its off it will down shift but i have to play with it for a little bit
can any one help me what should i do
I'll bet you didn't line up 1 of the arrows on the pressure plate with the dimple on the inner clutch hub. The pressure plate doesn't mesh with the inner hub properly and it ends up looking like this.
i took it back apart the presher plate looks to be lined up when i pull the clutch lever in i can see olny the first 3-4 plates push out
my clutch was working great untill i took it off to replace the the broken bolt for the shifter spring
It's not rocket science. The springs push on the pressure plate. The pressure plate clamps the steels and fibers together and makes the bike go. Something is obviously holding the pressure plate away. The pressure plate can go 6 different ways. Only 3 will work. If that's not it, and you have free play at the lever, then you're just going to have to take it apart and see what you assembled wrong.
You are using a torque wrench on the 6 pressure plate bols, right?
As much as we would like to help you, only you can take it all back apart and find what you put together wrong. Make sure the clutch cable housing is properly in the end holders. Check the washer before and after the basket. Go back through the bottom end assembly walkthrough. Let us know what you find.
