Mr..Red Posted October 10, 2012 Report Share Posted October 10, 2012 After doing a search online and asking a few people I cant not get a solid responce. I have seen online that the "cool heads" are a very well talked about topic. Ill keep it short and sweet and hope to get some info. 2002 banshee cool built heads t5' exhaust stock rad and over flow tank. I picked it up and rode it one time and it seemed fine. I took out again this past weekend for some good riding and I had noticed the over-flow tube for the coolant was dripping.... I had added coolant to the back tank before going out which was probably the wrong thing to do but i was in a rush to ride ( who isnt ) and I was curious if the rear over-flow tank was low due to the quad having "cool built heads". Do the cool heads require less coolant ? Is this possible....? I almost felt like all the coolant I added pissed out the over-flow tube that is up front by the rad... PLEASE PLEASE HELP........................... thanks guys. From the noob on here. lol. Quote Link to comment Share on other sites More sharing options...
old put-put Posted October 10, 2012 Report Share Posted October 10, 2012 The cool head actualy holds more coolant than a stocker. If your losing coolant by the overflow tube at the radiator then you have a hose or radiator leak. Check the radiator to see if it is full and then your hose routing, the overflow from the radiator goes to the bottom nipple of the overflow bottle and the top nipple on the bottle goes to the ground. Quote Link to comment Share on other sites More sharing options...
Man-O-Steele Posted October 10, 2012 Report Share Posted October 10, 2012 you should probably look at your plugs to see if its lean and also check your jetting. could be getting hot due to a lean condition. good luck. Quote Link to comment Share on other sites More sharing options...
Mr..Red Posted October 10, 2012 Author Report Share Posted October 10, 2012 Thanks guys.... The coolant was coming from a small coolant line and it wasnt dripping all the time. Im going to look into it more this weekend...I hope. due to working 24.7 When I did open the rad I did NOT see any coolant at the top. Should I top off the Rad when its cold and then run it and see what happens ? I didnt see any other "leaks" other than the over-flow tube that was routed right obove the right side exhaust. Quote Link to comment Share on other sites More sharing options...
Finch Posted October 10, 2012 Report Share Posted October 10, 2012 if its gotten colder since ya last rode it its prolly lean and over heating coolant boiling over is a good sign of over heating Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted October 10, 2012 Report Share Posted October 10, 2012 That overflow tank should be empty when your bike is cold, and the radiator is full. It's not a coolant "reservoir". It's simply an overflow to keep the tree huggers happy. Nonetheless, most of us throw those bottles away, and let the bikes piss coolant onto the ground because we're hardcore like that. x3 on the lean condition, and I'm adding a "bad cap" to that... Try replacing your cap once you've determined your jetting is not lean. Quote Link to comment Share on other sites More sharing options...
Mr..Red Posted October 10, 2012 Author Report Share Posted October 10, 2012 Thanks... I was reading that a lot of people ditch the over-flow bottle in the back. If that should be empty when cold then it would make sence why it would be pissing it out...no ? Like a dumbass I added coolant in the back to the "FULL" line cause I was to lazy and wanting to ride to to take the front plastics off to check the rad... So would that make sence that it was pissing out all the coolant I added to the back ? Quote Link to comment Share on other sites More sharing options...
Finch Posted October 10, 2012 Report Share Posted October 10, 2012 id still check to make sure your not lean!! Quote Link to comment Share on other sites More sharing options...
Mr..Red Posted October 10, 2012 Author Report Share Posted October 10, 2012 Im def going to check the plugs. Any other way to check if its lean ? Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted October 10, 2012 Report Share Posted October 10, 2012 If you over fill your coolant it will spit out the extra coolant Quote Link to comment Share on other sites More sharing options...
ECshee Posted October 10, 2012 Report Share Posted October 10, 2012 i just like the thread title. touche` Quote Link to comment Share on other sites More sharing options...
db25 Posted October 10, 2012 Report Share Posted October 10, 2012 Plug chops.. Best way to see if you're lean.. Quote Link to comment Share on other sites More sharing options...
2strokeBEAST Posted October 11, 2012 Report Share Posted October 11, 2012 If you haven't got the time right now to check your jetting and do a chop, at least throw out your current jet settings. AND your elevation and temp, since we can't look that up for you, like we usually would if you revealed your location haha!! Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 11, 2012 Report Share Posted October 11, 2012 I found this - http://kuoi.com/~john/tips.html ,I had the same problem this past weekend at the dunes.When I top a dune I sit downhill waiting on the wife., my bike was not hot but dribbled out the overflow. The reservoir was half full and the radiator was full. I didn't understand how it would puke out the overflow hose when the bottle was not full. I also have T5's and a Coolhead. I think the tank and hose placement is a bad design explained by this attachment. I'm also just sure it is a Recirculating system since the hose from the radiator is on the bottom and the drain hose comes off the top and is made to drip on the right pipe so you can smell it. but I have read to the contrary. Quote Link to comment Share on other sites More sharing options...
Mr..Red Posted October 11, 2012 Author Report Share Posted October 11, 2012 Well the location that I was riding in when it happened was in the mountains of P.A. Far as the jets Im not sure to be honest. The bike was piped and jetted when I bough it. ______________________________________________________________ Far as the link to the write up I also came across that when I did a search. Seems like a simple fix for an idea. I cant wait till I get a little more time on my hands to really get into my new toy. THANKS FOR ALL THE HELP AND IDEAS GUYS!!!!!!!!!!! Much appreciated. Quote Link to comment Share on other sites More sharing options...
