erock1911 Posted October 1, 2012 Report Share Posted October 1, 2012 Im bout to purchase a set of pipes and CANNOT decide between toomys or CPI inframes, i ride mostly open feilds, dunes occasionally My mods: stock stroke, .50 bore on the stock cylinders mild port i beleive the exhaust port has been polished, cool head, no airbox.. What pipes better? i know the cpi has little more on top but i dont constanly run wide open i want it to run like a ape.. currently have pro circut platnums will i notice a difference? Quote Link to comment Share on other sites More sharing options...
dunesovertrails Posted October 1, 2012 Report Share Posted October 1, 2012 Im bout to purchase a set of pipes and CANNOT decide between toomys or CPI inframes, i ride mostly open feilds, dunes occasionally My mods: stock stroke, .50 bore on the stock cylinders mild port i beleive the exhaust port has been polished, cool head, no airbox.. What pipes better? i know the cpi has little more on top but i dont constanly run wide open i want it to run like a ape.. currently have pro circut platnums will i notice a difference? I think you'd like the cpi's Quote Link to comment Share on other sites More sharing options...
Dicklez Posted October 1, 2012 Report Share Posted October 1, 2012 keep the circuits or go with the t-5 on your setup imo. Quote Link to comment Share on other sites More sharing options...
possum Posted October 1, 2012 Report Share Posted October 1, 2012 without knowing ur port timing its hard to say if the cpis will benefit u. pc might be just fine. Quote Link to comment Share on other sites More sharing options...
SandmanPNW Posted October 1, 2012 Report Share Posted October 1, 2012 CPIs are where its at! Quote Link to comment Share on other sites More sharing options...
10milbansheerider98 Posted October 1, 2012 Report Share Posted October 1, 2012 To what I'm seeing of the mods you got... I'd go with CPI's or you should look up snipers, they can hand make the best suitable pipes to match the performance of your engine. Just tell them the mods you got on yours and they will make it. Quote Link to comment Share on other sites More sharing options...
06bansheeboi Posted October 1, 2012 Report Share Posted October 1, 2012 I have cpi inframes on a .10over very mild port work. My bitch screams. Go with cpi... Quote Link to comment Share on other sites More sharing options...
SuperMex Posted October 1, 2012 Report Share Posted October 1, 2012 Shearers!!!!! Quote Link to comment Share on other sites More sharing options...
Colby Posted October 2, 2012 Report Share Posted October 2, 2012 Shearers!!!!! junk Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted October 2, 2012 Report Share Posted October 2, 2012 shearers, cpi, or sniper smallbore inframes i would go with. save $ for the future as in time you will want more power and the pipes will still work unless you take a huge jump Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted October 2, 2012 Report Share Posted October 2, 2012 Much will depend on what exactly has been done to your cylinders. IMO if you have the PC's you won't appreciate the Toomey's, you'll see very little if any top end gain and will suffer a loss on bottom. The CPI's will offer a slightly higher reving power delivery that will also come on a bit later (with the right porting). The Shearers are going to have a better fit/finish than the CPI's, but they will come on a bit later and will rev quite a bit further (again with the right porting). -Brandon Quote Link to comment Share on other sites More sharing options...
thomas h. Posted October 2, 2012 Report Share Posted October 2, 2012 Pc is good where your at. I would build a ported 4 mill way way way ......way befor upgrading from PC pipes. After the bigger ported motor you with still be fine with pc. Then get the shearers and a pair of air strikers 35mm. Quote Link to comment Share on other sites More sharing options...
Colby Posted October 2, 2012 Report Share Posted October 2, 2012 The Shearers are going to have a better fit/finish than the CPI's -Brandon is this a joke? Quote Link to comment Share on other sites More sharing options...
SuperMex Posted October 2, 2012 Report Share Posted October 2, 2012 is this a joke? Quote Link to comment Share on other sites More sharing options...
thomas h. Posted October 2, 2012 Report Share Posted October 2, 2012 is this a joke? Don't you have to trim your plastic with CPI ? Shearer no trimming. Quote Link to comment Share on other sites More sharing options...
