xjmav Posted September 27, 2012 Report Share Posted September 27, 2012 I have an 85 or 86 cr250 for sale. Back when they still had power. The motor has had brand new machine work done to it. New piston and bearings. The head has been milled, nickasil plating bored out and sleeved. Machine work from ridge reamer. The crank was sent out to crankworks in Arizona and rebuilt with new bearings and a new rod. Also new crank bearings in the case. I have a full gasket set to go with, the new piston as well as the repair manual. I have over a grand in the machine work and new parts alone. The bad, when i wass putting the motor back together, stripped 2 case bolts out and i just lost interest. Needs to be drilled with a helicoil repair or welded and re tapped. Any machine shop should be able to complete this for very cheap. I just havent had the time. Quote Link to comment Share on other sites More sharing options...
xjmav Posted September 27, 2012 Author Report Share Posted September 27, 2012 Quote Link to comment Share on other sites More sharing options...
shakar Posted September 27, 2012 Report Share Posted September 27, 2012 im looking for an aftermarket exhaust for my 87. any idea if or what years are interchangable??you selling your pipe/silencer ??lmk thanks Quote Link to comment Share on other sites More sharing options...
