questions for the wise
BLOODRAGE
well the description pretty well says it.ill be running 72.5mm pistons on a 10mil crank.
which carbs will be the best for this setup.
id prefere mikunis because the jets are dime a dozen unlike kehin where they seem like they are obsolete around here.
so which size?
so which size?
39mm pkw is the best to run
Jeepers! Stock carbs on a 10 mil!
I'd run 39 PWK's. Easy carb to tune and works well on big motors. Mikunis are nice for methanol because you can switch out the dumps easy, if your on gas IMO stick with Keihin.
Sounds crazy right and I still beat all the 450's and big cc utility bikes lol
