Pwks jetting
slow03
i had 360m and 27.5p when i was using stock carbs.. since switching to pwk35s im using 152m 52p.. that should be fairly close id say. but if i were you id probably start at 160-165m for your first plug chop and work your way down from there! youd rather start on the rich side and work you way down! hope this helps
