Nightmare Posted September 27, 2012 Report Share Posted September 27, 2012 Well, I got it figured out. The piece that the brake lever actually attaches to in the new rebuild kit I used was an inch longer than the stock one. So basically, it was already pushing the piston up far enough to keep fluid from coming in. Once I figured that out, it took about 4 minutes to bleed the brakes. I just swapped it out with the stock one I had. Stupid ass rebuild kit. Thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 27, 2012 Report Share Posted September 27, 2012 JUNK!!! Quote Link to comment Share on other sites More sharing options...
old put-put Posted September 27, 2012 Report Share Posted September 27, 2012 Yeah sometimes the obvious can be overlooked or not noticed. Glad you're back up and running. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 27, 2012 Author Report Share Posted September 27, 2012 Yeah sometimes the obvious can be overlooked or not noticed. Glad you're back up and running. It really wasn't obvious though. I didn't have any reason to assume they were different until I compared it to the stock one. I wonder how many people have had the same issue from using that rebuild kit? Quote Link to comment Share on other sites More sharing options...
old put-put Posted September 28, 2012 Report Share Posted September 28, 2012 It really wasn't obvious though. I didn't have any reason to assume they were different until I compared it to the stock one. I wonder how many people have had the same issue from using that rebuild kit? Was this on a 450 conversion, or banshee frame, was it a 450 master cylinder kit or for a banshee? Is there a difference in the plunger rod between the two, or just the kit had something different? Not pointing fingers or badmouthing anyone, but we have all overlooked or didn't pay attention as close as we should have and caused us issues that made us want to kick ourselves in the rear when we found out what the problem was! Quote Link to comment Share on other sites More sharing options...
quaddad817 Posted September 28, 2012 Report Share Posted September 28, 2012 you need shannon purdy to suck on the bleeder hose! he can actually pull 300 inch pounds of vacume! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 28, 2012 Author Report Share Posted September 28, 2012 Was this on a 450 conversion, or banshee frame, was it a 450 master cylinder kit or for a banshee? Is there a difference in the plunger rod between the two, or just the kit had something different? Not pointing fingers or badmouthing anyone, but we have all overlooked or didn't pay attention as close as we should have and caused us issues that made us want to kick ourselves in the rear when we found out what the problem was! BANSHEE FRAME. BANSHEE MASTER CYLINDER REBUILD KIT. I didn't overlook shit. The threaded part that the brake lever attaches to was almost an inch longer from the rebuild kit. When I hooked up the brake lever it was pushing the piston so far up in the master cylinder it wouldn't let brake fluid into the cylinder. After examining my old stuff I noticed the lengths were different. I swapped them and then it took 4 minutes to bleed the brakes. I assume it was a Banshee master cylinder rebuild kit because everything else worked. I am not familiar enough with a 450 master to determine whether or not it could be used on it as well. you need shannon purdy to suck on the bleeder hose! he can actually pull 300 inch pounds of vacume! Hahahaha. Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted September 28, 2012 Report Share Posted September 28, 2012 You mean the owner of the worlds largest Banshee website (ego boost) can't even bleed his brakes?!?!?!?!?! I'm just kidding Tyler, I remember the first time I bled my brakes too. Very scary and difficult time for me. :rotflmao: :rotflmao: Quote Link to comment Share on other sites More sharing options...
old put-put Posted September 28, 2012 Report Share Posted September 28, 2012 What brand was the rebuild kit? Maybe post it so if others bought the same, they would know to look at the pusher rod so they do not run into the same issue you had. Quote Link to comment Share on other sites More sharing options...
quaddad817 Posted September 28, 2012 Report Share Posted September 28, 2012 but on the real..... sometimes you have to take the pin out of the clevis that ataches the brake lever to the master and use a screwdriver to push it all the way in and pull it out. (full stroke) bet this works unless its just bad Quote Link to comment Share on other sites More sharing options...
