banshee wont kick start
chevy913
Kick started fine then decided to ditch the j arm and go to a arm now it won't kick start but will start when pushed and dropping the clutch. Any ideas?
Could just be a coincidence, but do a compression check. Sounds like you've got low compression. Do a leakdown test as well, and see if you've got any significant air leaks keeping it from starting.
Bad gas.
