Frizb99 Posted November 18, 2013 Report Share Posted November 18, 2013 talked with trail tech about this and the stock stator output on a dc conversion is only 35 watts TOTAL so you can only run led lights. Or get the 200 watt stator and you are good to 150 dc watts. Sorry, but I'm going to have to dissagree. The stock stator is designed to handle 2 35w headlights and roughly 10w for the taillight. Search for "Q#62" on the Banshee Electrical FAQ http://bansheehq.com/forums/index.php?showtopic=133650&p=1154447 It should be noted that the factory stator lighting coil can only handle two 30-35W headlights, or about 70W total (a little more for the taillight). Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted November 18, 2013 Report Share Posted November 18, 2013 You don't get the full amount of power through a dc conversion Quote Link to comment Share on other sites More sharing options...
Coupelx Posted November 18, 2013 Report Share Posted November 18, 2013 But I doubt it cuts it in half. Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted November 18, 2013 Report Share Posted November 18, 2013 From what I've gathered about 15-20% Quote Link to comment Share on other sites More sharing options...
gst_r Posted August 12, 2015 Report Share Posted August 12, 2015 I know this is an old topic, but anyone have the PDF from trail tech? It is not available at the link! thanks! Quote Link to comment Share on other sites More sharing options...
gst_r Posted August 12, 2015 Report Share Posted August 12, 2015 I am looking into running some led dc lights, I am trying to figure out "floating the ground", right now as I understand, I need to desolder the ground on the stator, then put an extension to the desolded wire and this one will go out to the rectifier right? thanks in advance!! Quote Link to comment Share on other sites More sharing options...
gst_r Posted August 13, 2015 Report Share Posted August 13, 2015 I guess I already figured out the whole process but I have read mixed commens about using a battery on led lights, I am planning to run a pair of 10w led lights at stock location using the low beam, and a led light bar 30w mounted at handle bars on high beam....thanks again Quote Link to comment Share on other sites More sharing options...
gst_r Posted August 13, 2015 Report Share Posted August 13, 2015 thanks man! Right now I will be using this diagram, I guess the Red wire will only go to the switch and the black to ground at frame (wires from the new rectifier) right? Quote Link to comment Share on other sites More sharing options...
Hankdiggity Posted September 9, 2015 Report Share Posted September 9, 2015 Anyone have experience with the Race Tech Electric stator/regulator/rectifier kit? Want to mount Rigid D2 Duallys or Baja Designs Squadrons up, but do not want to mount in much of a battery. How big of a battery is needed, what have you seen working? Anyone running any of these lights? Quote Link to comment Share on other sites More sharing options...
turbo-2nr Posted March 14, 2016 Report Share Posted March 14, 2016 I have d2s, stock stator floated, regulator rectifier off of a mercury 90hp outboard (nice but cheap on ebay)and a tx14 size battery 5.75 wide X 5.75 tall X 3.5 deep. Mounted behind the stock air box 1 Quote Link to comment Share on other sites More sharing options...
