Zbb Posted September 18, 2012 Report Share Posted September 18, 2012 Installed fmf fattys and powercore2 and rejetted to a 280 jet and now it won't start need help Quote Link to comment Share on other sites More sharing options...
Nightmare Posted September 18, 2012 Report Share Posted September 18, 2012 Do u have spark? Quote Link to comment Share on other sites More sharing options...
lms1977 Posted September 18, 2012 Report Share Posted September 18, 2012 are you sure you have the cross over tube in between the carbs, are the bowls on the correct carbs and slides in right? Quote Link to comment Share on other sites More sharing options...
Zbb Posted September 18, 2012 Author Report Share Posted September 18, 2012 I got it to start now it revs high and won't idle Quote Link to comment Share on other sites More sharing options...
1CrazyBastard Posted September 18, 2012 Report Share Posted September 18, 2012 I got it to start now it revs high and won't idle How high does it rev ?? If it just revs to wot then look at your carb sllides the needles or a needle might be stuck and didnt go into the carb properly holding the slide up or the slide groove might not be lined up in the carb Quote Link to comment Share on other sites More sharing options...
Zbb Posted September 18, 2012 Author Report Share Posted September 18, 2012 Ok I'll look into that Quote Link to comment Share on other sites More sharing options...
1CrazyBastard Posted September 18, 2012 Report Share Posted September 18, 2012 Pull air filter and look into the carb throats do you see both slides all the way down ? if not check needle is in center of carb properly when you installed carb top and the grove in the slide is lined up with the pin in the carb so it can go in properly Quote Link to comment Share on other sites More sharing options...
Zbb Posted September 18, 2012 Author Report Share Posted September 18, 2012 A slide was stuck I got it up and going and there's no power on the top end Quote Link to comment Share on other sites More sharing options...
y2ks Posted September 18, 2012 Report Share Posted September 18, 2012 What is your elevation? Quote Link to comment Share on other sites More sharing options...
y2ks Posted September 18, 2012 Report Share Posted September 18, 2012 Does it run fine till wot what mods do you have is it just pipes Quote Link to comment Share on other sites More sharing options...
Zbb Posted September 18, 2012 Author Report Share Posted September 18, 2012 No more than 3000 ft yea jus the pipes Quote Link to comment Share on other sites More sharing options...
y2ks Posted September 18, 2012 Report Share Posted September 18, 2012 Sound like you to rich! Being to rich on the top end will sometimes cause your engine to rap out and not make any power and make the engine overheat. If it only happens at the wot its in your main jets im at 1100 and have almost the same mods and i run a 180 main and im dialed in you are much higher at 3000 with less air hope this helps. Quote Link to comment Share on other sites More sharing options...
1CrazyBastard Posted September 18, 2012 Report Share Posted September 18, 2012 Do yourself a favor and read the info here http://www.dfn.com/agservices/jetfaq.html lots of good info and it will help you get it where it needs to be Quote Link to comment Share on other sites More sharing options...
Zbb Posted September 18, 2012 Author Report Share Posted September 18, 2012 Ok thanks Quote Link to comment Share on other sites More sharing options...
