dunner250 Posted September 17, 2012 Report Share Posted September 17, 2012 Dammit this sucks! What caused this? Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted September 17, 2012 Report Share Posted September 17, 2012 (edited) 1. Did you mix you fuel ? 2. Did your motor pass leakdown test with no air leaks ? 3. Was your jetting right ? There are several factors that could have cause this, you may want to check over everything when you rebuild the motor. Hows the crank ? Are the bearings tight on the rods ? Edited September 17, 2012 by Infamous039 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 17, 2012 Report Share Posted September 17, 2012 1. Motor got hot. 2. Taiwan decided to blow up your motor. Quote Link to comment Share on other sites More sharing options...
dunesovertrails Posted September 17, 2012 Report Share Posted September 17, 2012 Holy shit thats a messed up piston. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted September 17, 2012 Report Share Posted September 17, 2012 Heat Lemme guess.....It ran real strong right up until it didn't, and you never heard a thing till it just locked up. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted September 17, 2012 Report Share Posted September 17, 2012 Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted September 17, 2012 Report Share Posted September 17, 2012 Loos like you had a massive air leak on the right side. Quote Link to comment Share on other sites More sharing options...
Nieskes Posted September 17, 2012 Report Share Posted September 17, 2012 Looks fine to me. Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted September 17, 2012 Report Share Posted September 17, 2012 looks like one of trinitys piston kits. Quote Link to comment Share on other sites More sharing options...
dunner250 Posted September 17, 2012 Author Report Share Posted September 17, 2012 Prior to this I had a reed that was chip, but it was replaced. It failed shortly after that. Quote Link to comment Share on other sites More sharing options...
guns4children Posted September 17, 2012 Report Share Posted September 17, 2012 Do you guys really use sealer at the reeds? Quote Link to comment Share on other sites More sharing options...
guns4children Posted September 17, 2012 Report Share Posted September 17, 2012 Well slap my cock and call me DDQ. I might just do that before my next ride. U put it on each side of the gasket? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 17, 2012 Report Share Posted September 17, 2012 Hmm, no sealer on my shit. What intakes you guys using? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
BUILDER Posted September 17, 2012 Report Share Posted September 17, 2012 I would say massive air leak on that side. Hmmmm I have never used sealer on my reeds. I think you guys need better intakes! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 17, 2012 Report Share Posted September 17, 2012 Chariot. Actually K&T recommended I do it. Said most engines leak there, sure enough after I put the gaskets and intakes on and pressurized it, sprayed it with windex and the right side bubbled up. Put a little 1211 and that was the end of that leak. Well I'll be dipped in dog shit... Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
