Cleaned K&N now it bogs
XXDEF1ANTXX
My trick is to stick the filter on the end of my shop vac hose. I use the aerosol K&N oil. Then with the vac running, I spray paint the filters with oil from just far enough away that all the oil mist is drawn into the filter. It gives the filter a nice even coat of oil with very little wasted in overspray. If you heard the vac motor pitch change, you will know for sure you over did it. I make 2 light passes. One spraying clockwise and the other counter clockwise. That way your sure to spray the faces of each pleat.
NOTE: The shop vac idea is a great way to make sure the filter has totally dried before you oil it. Just let it pull through the filter for 5 min......Speeds things up if your rushing to prep for a ride. ;)
