Im going to be putting a 4sp in my mud truck sometime this week and Im wanting to run stacks out the hood because I have like 4 grand in the 327 motor. So the last thing I want to do is pull some water in it. The motor is sittin on a 1 ton frame and runnin gear but has a s15 body sitting over it. So it has very little room and wondered if I could get some block hugger headers and turn them up. And its loud as hell with longtubes but its better to tolerate some noise than screw up a motor.
Its gonna take a big ass hole of water to get up to the carb. Its lifted 8in and is up about 4ft off the ground.
If I run the an exhaust under the truck that would be risky because I will be going through some deep holes and the exhaust would be under the water. And you never know what might happen and it shut off there goes the motor. And if I run it through the hood problem sovled. I know I wont be in mudholes plum up to the motor that would be stupid.
The truck currently has a wooden bed but I will be gettin a steel bed put on it later. And I will run the stacks through the bed when I put in on but for the meantime I was just wanting to put them on there so I dont screw my motor up. And as far as power goes I dont think I miss much with the change for a bit. The truck currently has 450hp and i dont think I will miss much of it. I can get a cheap set of block hugger for 75 bucks just to throw on there until I can get my steel bed made.
