Banshee Chad Posted September 15, 2012 Report Share Posted September 15, 2012 So I've never really paid attention before. But I'm working on getting jetting dead on. So the washer thing that the cable goes into and holds the needle into the slide... Does it go in so the hole is open or covered? Does it make a diff? What's the hole thre for? I looked in clymers, but no diagram about that. Thanks guys! Quote Link to comment Share on other sites More sharing options...
y2ks Posted September 15, 2012 Report Share Posted September 15, 2012 Post a picture so we can see what washer you are talking about Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted September 15, 2012 Author Report Share Posted September 15, 2012 I know, tried..having trouble uploading to Photobucket... I'll keep trying. It's the piece that goes in the slide..that holds the needle in. Has 2 screws. Quote Link to comment Share on other sites More sharing options...
Finch Posted September 15, 2012 Report Share Posted September 15, 2012 pb it fubar'd good thing i came to the rescue! Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted September 15, 2012 Author Report Share Posted September 15, 2012 pb it fubar'd good thing i came to the rescue! I hope your right. But also want an understanding of why it's there, what's it do. Is it Iike a boost of some sort when get a high enough hp bike? Quote Link to comment Share on other sites More sharing options...
Finch Posted September 15, 2012 Report Share Posted September 15, 2012 if ya have a clymers it will show ya the right way im just to lazy to look but my guess is let gas and oil that gets up there drain back into the carb. Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted September 15, 2012 Author Report Share Posted September 15, 2012 I looked at clymers, didn't say either way that I could find. Quote Link to comment Share on other sites More sharing options...
Finch Posted September 15, 2012 Report Share Posted September 15, 2012 ah ya well im sure you got it right. then Quote Link to comment Share on other sites More sharing options...
special06shee Posted September 15, 2012 Report Share Posted September 15, 2012 If you were to take a part a virgin carb from the factory the needle hold down will be blocking the hole.. I have tried it either way out of curiousity and it made zero difference.. I do however assemble it with the hole blocked so that any debree that sneaks its way through the cables will not get into the carbs itself! Quote Link to comment Share on other sites More sharing options...
1CrazyBastard Posted September 15, 2012 Report Share Posted September 15, 2012 It has to stay open or is suppose to as the slide could compress the air like a piston does so the hole is suppose to stay OPEN here is something i copy and pasted from toomey racing There is a hole in the bottom of the slide on the inside as you look down from the top. Also notice there is a passage way on the aluminum cable holder too. These must lineup! (See photo) The purpose of this passage is so that the slide has an air vent to the top of the carb. Otherwise, the slide would act like a piston in a cylinder and compress air above it. Once the compressed air blew out down the sides of the slide between the slide and the slide bore, the slide might stick on the way down because of the resulting vacuum created. 1 Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted September 15, 2012 Author Report Share Posted September 15, 2012 It has to stay open or is suppose to as the slide could compress the air like a piston does so the hole is suppose to stay OPEN here is something i copy and pasted from toomey racing There is a hole in the bottom of the slide on the inside as you look down from the top. Also notice there is a passage way on the aluminum cable holder too. These must lineup! (See photo) The purpose of this passage is so that the slide has an air vent to the top of the carb. Otherwise, the slide would act like a piston in a cylinder and compress air above it. Once the compressed air blew out down the sides of the slide between the slide and the slide bore, the slide might stick on the way down because of the resulting vacuum created. Interesting, then why would it come blocked from factory? Tors would help in the event of a stick. Did they know wed all get rid of tors? Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted September 15, 2012 Author Report Share Posted September 15, 2012 (edited) Picture 1 or 2? Edited September 15, 2012 by Banshee Chad Quote Link to comment Share on other sites More sharing options...
special06shee Posted September 15, 2012 Report Share Posted September 15, 2012 Well i misinformed you.. i stand corrected! The hole is open!! I just looked at my stocker!! Sorry about the mix up Quote Link to comment Share on other sites More sharing options...
1CrazyBastard Posted September 15, 2012 Report Share Posted September 15, 2012 Picture 1 or 2? pic 2 is the proper way according to toomey however I installed mine with the hole closed and it didnt seem to make any difference in the way it ran or effect the throttle .I have since made sure both of my slides are like pic 2 Quote Link to comment Share on other sites More sharing options...
1CrazyBastard Posted September 15, 2012 Report Share Posted September 15, 2012 If I had not just gone thru the same exact thing just two weeks ago I would Not have known but I just got an eduaction on banshee carbs the hard way and made several mistakes this being one of them . I just got the thing and hell I didnt even know what a Banshee was three mos ago Quote Link to comment Share on other sites More sharing options...
