miami350 Posted September 10, 2012 Report Share Posted September 10, 2012 hey there havinh some problem with my 1-4m5,6 N-DOWN its hard to shift to neutral when motor is running but easy to find neutral when motor is off is the tranny goin bad?? or is it easy to fix??? Quote Link to comment Share on other sites More sharing options...
toytech Posted September 10, 2012 Report Share Posted September 10, 2012 hey there havinh some problem with my 1-4m5,6 N-DOWN its hard to shift to neutral when motor is running but easy to find neutral when motor is off is the tranny goin bad?? or is it easy to fix??? sounds like you clutch is not releasing properly. Quote Link to comment Share on other sites More sharing options...
miami350 Posted September 10, 2012 Author Report Share Posted September 10, 2012 sounds like you clutch is not releasing properly. what you mean about that?? Quote Link to comment Share on other sites More sharing options...
quadpro26 Posted September 10, 2012 Report Share Posted September 10, 2012 means the clutch is dragging while the lever is in, needs adjustment Quote Link to comment Share on other sites More sharing options...
