bansheecbr600rr Posted September 9, 2012 Report Share Posted September 9, 2012 I have banshee with a cbr 600, the rear caliper on the quad is off the cbr as well works great! This is a 1987 banshee, will the front break calipers fit off 90 or newer ? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted September 9, 2012 Report Share Posted September 9, 2012 I have banshee with a cbr 600, the rear caliper on the quad is off the cbr as well works great! This is a 1987 banshee, will the front break calipers fit off 90 or newer ? NO, not unless you put the 1990-2006 spindles on it. Quote Link to comment Share on other sites More sharing options...
bansheecbr600rr Posted September 9, 2012 Author Report Share Posted September 9, 2012 NO, not unless you put the 1990-2006 spindles on it. so the spindles will swap over (direct bolt on?) Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted September 10, 2012 Report Share Posted September 10, 2012 Yes the spindle are a direct bolt on. But the early caliper actually has a bigger brake pad for better fade resistance. So I would either stay with the early calipers and pads, OR I would put a set of late style Banshee spindles on and then put a set of early YFZ450 calipers on them. The YFZ calipers are dual pistons and they are supposed to be a direct bolt on to the late Banshee spindles. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted September 10, 2012 Report Share Posted September 10, 2012 I have a bunch of the 87-89 calipers if you need some. Quote Link to comment Share on other sites More sharing options...
