Ronnie Posted September 5, 2012 Report Share Posted September 5, 2012 Hi, I have a 99 Banshee and I want to replace the headlight guards. How do I do this? Do they just pop off? Should I use a Flathead screw driver to do it? Quote Link to comment Share on other sites More sharing options...
ELP Posted September 5, 2012 Report Share Posted September 5, 2012 Hi, I have a 99 Banshee and I want to replace the headlight guards. How do I do this? Do they just pop off? Should I use a Flathead screw driver to do it? You have to disassemble the headlight. Quote Link to comment Share on other sites More sharing options...
ginger Posted September 5, 2012 Report Share Posted September 5, 2012 there is a small screws you have to pull out, if you dont, your just going to fuck up the guard. Quote Link to comment Share on other sites More sharing options...
Ronnie Posted September 5, 2012 Author Report Share Posted September 5, 2012 there is a small screws you have to pull out, if you dont, your just going to fuck up the guard. Is it that single screw on the bottom of the light? The guards are broke and I want to replace them. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted September 5, 2012 Report Share Posted September 5, 2012 Is it that single screw on the bottom of the light? The guards are broke and I want to replace them. No, that is the aiming screw. If they are the early glass lenses, the guards should pop off with a screwdriver. If they are the later plastic lenses, you have to replace the entire outer ring or if you don't want them on there just cut them off with a cutoff wheel and smooth up the edges. Quote Link to comment Share on other sites More sharing options...
Ronnie Posted September 5, 2012 Author Report Share Posted September 5, 2012 No, that is the aiming screw. If they are the early glass lenses, the guards should pop off with a screwdriver. If they are the later plastic lenses, you have to replace the entire outer ring or if you don't want them on there just cut them off with a cutoff wheel and smooth up the edges. Its a 1999 Quote Link to comment Share on other sites More sharing options...
Ronnie Posted September 6, 2012 Author Report Share Posted September 6, 2012 (edited) Its a 1999 and for the life of me I cannot get them off all I am doing is messing up the outer casing. Something is holding them on cause one is half broken and i cant even pull that one off. What am I doing wrong? Edited September 6, 2012 by Ronnie Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted September 6, 2012 Report Share Posted September 6, 2012 (edited) Theres a small screw underneath you have to take out, not the tiny screw that will be facing you thats the adjuster, the one thats pointing down. Once thats out it will slide out, it has a little piece that catches on top of the cover you'll see what i mean, it slides into place. If the little plastic grill is messed up on the covers just cut them all flush with the housing, looks better imo. Number 11 is what holds it in place. Edited September 6, 2012 by ATVRidinManiac Quote Link to comment Share on other sites More sharing options...
Ronnie Posted September 6, 2012 Author Report Share Posted September 6, 2012 Theres a small screw underneath you have to take out, not the tiny screw that will be facing you thats the adjuster, the one thats pointing down. Once thats out it will slide out, it has a little piece that catches on top of the cover you'll see what i mean, it slides into place. If the little plastic grill is messed up on the covers just cut them all flush with the housing, looks better imo. OK I found them and they are both striped out. Any ideas on how to get them out? Quote Link to comment Share on other sites More sharing options...
Ronnie Posted September 6, 2012 Author Report Share Posted September 6, 2012 I got one out but the other screw is in bad shape. You guys know any tricks to get it out? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 6, 2012 Report Share Posted September 6, 2012 I got one out but the other screw is in bad shape. You guys know any tricks to get it out? Take a dremel and cut a notch in it for a flat screw driver. Quote Link to comment Share on other sites More sharing options...
