Oil leak.
jsinar
I've got a slight oil leak coming from somewhere, I have no idea where tho. It'll puddle in the flat spot below the sprocket. The oil that's there is a grayish color, but my trans fluid is still red. I can wash it out, and after I ride for a while, it starts to pool up again. I'm not losing any trans fluid, it's at the same level it was when I bought it back in june. The only thing I see leaking is the shift shaft seal is damp, but it's far enough back it doesn't sit over that flat spot, it would just drip on the ground. Unless that little white plastic cover's gasket (the one that's behind the case saver) is leaking some. If it is what is that called so I can get a gasket for it?
