  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
What's wrong with your domes?
Blew Oring after 3 rides. Think I want to try a different dome design. I'm not detonating, running rich with mild timing. Squish at 50 and 155psi each side. Doesn't make sense.
Brandon at Wildcard did mine. Call him and share your info and he can have them out to you right away. I'm also sure he can help shed some light on your current issue with o-rings.
Good luck.
Troy
David noss @ noss machine
Brandon @ Wildcard
Jeff @ Fast
Kevin @ HJR
Andy @ No Limit Powersports (mm Atv)
Cam @ Redline
They all do solid domes! Find who you click with and give it a go.
Brandon @ Wildcard
Jeff @ Fast
Kevin @ HJR
Cam @ Redline
one of those is not like the other cause I currently have a set by one and not impressed... (the last one)
anyone gone through Tim at Titan?
Edited by werner
I'd love to have Tim build me a motor.
Domes aren't everything folks, you cant just swap some in and go WOW there's that extra 10 HP I was looking for.
not expecting 10hp from a dome. love the way my bike runs just dont want to have to worry about changing orings twice a weekend like ive heard a few state has happened with a certain dome. im not a ragged edge rider. im more into dependability and treeshots then fast as fuck drag racing but with a drag ported 421 i know im on the edge of the later. just looking for that builder cause id like a little more compession (approx 180) with a safe squish. that all comes in dome design like squish band and dome shape.
Edited by werner
You obviously have never had Trinity set any domes up for you....because you couldn't be more wrong. If your domes and timing and pipes are all working together, you certainly can see big HP improvements.
Tim at Titan Racing did a set for me that proved that Trinity's domes were brutally bad.
Noss does great work and can get them to you in a heartbeat.
If your ordering domes for your motor and the only thing you ask for is a cc size....your doing it wrong.
Edited by WINDYCITYJOHN400
like i said if i were going for cc then i get a set of prodesign. im going for a dome that works with my all around setup. that hasnt happened with my current dome setup so im looking elsewhere. Is it true Tim had Noss cut his domes to specs? Im not mad at that if he does cause Ive had good luck with Noss.
Jeff at fast cut my domes, I have 175 comp and I have not blown an o ring yet. 2 years on my motor.
Sometimes Tim does send his specs to Noss and have Noss cut them. Then Noss will ship them to you. Tim charges around 125.00 to do this. Most of the Sponsors on this site will do the EXACT same thing for 75.00 (give or take). Up to you though.
Why not call the person that did your domes you are having problems with and allow them to try to remedy the situation?
so your saying redline fucked ur domes up?
I've had custom cut domes in my bike for years from the last one at about 180lbs compression no issues. So I got ask have you contacted him yet and if no why not I know he'd help ya out.
