600racer Posted September 3, 2012 Report Posted September 3, 2012 Hey y'all I'm in tie process of building a 4 mil stock cylinder with 65.5 bore running toomey pipes, just purchased some 34 pjs and billet intake and was wondering if you guys had any jetting ideas for premium gas, thanks Quote
600racer Posted May 17, 2015 Author Report Posted May 17, 2015 Running vforce 4 reeds carbs at a 160 main, 55 pilot, cel needle middle clip air screws 1.5 turn out has slight bog when I stab the throttle chokes out 7-7.5 bike idles a little low and I noticed that when I have both chokes out bog is gone any help would be awesome Quote
98_sheester Posted May 18, 2015 Report Posted May 18, 2015 If the bike is running bettsr with the choke out you might be a little lean usually...also when you get your slight bog does it hesitate and not wanna go faster or does it hesitate and then goes? Quote
600racer Posted May 18, 2015 Author Report Posted May 18, 2015 All right folks I was able to pin point where the problem was at I found that no matter what pilot I used herr recommended 48s lowest I had was 52s only could go .5 turns on air screw through some 55s in all the way to 62s I could not get past .5 turns through the 52s back in bike ran awesome so through the 55s in still ran awesome so I don't what the deal is with the air screws are so called herr and they said if that's where the bike likes it and runs the best leave at .5 so I'm going to try and lean it up a tad cuz I all ready order the dam 48s and some 50s. Any of you guys ever have this b4 Quote
sprinklerman Posted May 18, 2015 Report Posted May 18, 2015 Sentence too long to comprehend, ,,, cannot read (or help). Quote
600racer Posted May 20, 2015 Author Report Posted May 20, 2015 Sorry for the long sentence I now have have 158 mains with 55 pilots air screw .5 turns out Quote
sleeper06 Posted May 21, 2015 Report Posted May 21, 2015 I have seen relatively stock motors take 62-68 pilots with ghose carbs, I was a lil baffled but it wants what it wants. I usually keep adding pilot till the screw operates Quote
Darkblade Posted June 16, 2015 Report Posted June 16, 2015 hey i have a stage 3 port job with a cool head and 21 cc domes 65mm wiseco 795 pistons vf4 reeds uni pod filters fmf gnarly pipes with power core 2 silencers running a hot-rods 4mil long rod crank and stock carbs my areas temperature is between 75 and 95 degrees my elevation is between 600 and 850 ft what main jet and pilot jet size should i use and what should my needle jet be set on thanks Quote
