Squeaky noise
Update... I went to get on mine today and it was as bad as the OP... Found the source. Pull the bottom bolts out of your shock mounts, clean the metal tubes good and slather with some grease. I always use the green Lucas grease since its waterproof. The only thing you can hear now is the shocks working.
ive got the same noise in the same spot, maybe ill clean it up this weekend
