common problem?
rick7476
i just bought a le 04 banshee and im trying to take the plastic of and the two bolts that hold the tank cover on that go into the tank are spinning, i had this problem on my last bashee and got lucky and they both came out, the insert is spinning on both of them, any ideas how to get the bolts out, ive been spraying the bolts with wd-40 for a week hoping they would losing up but no luck. i dont want to wreak my gas tank cover
I had the same problem.. Ended up cutting the head of the bolts off.. Them removing the sleeve itself from the tank mold! I was to cheap to buy another tank so i just found nuts that fit the tank shroud bolds and epoxyed them back in the tank!! It works!!
This. It took me about 4 bikes to find a tank that was perfect
It's a real easy fix.
Just hook your drill to the bolts and spin out the entire assembly. Then go to Home depot and get a couple of press in anchors. Works perfect.
I 'll try to find a picture of what you will be looking for at home depot.
Real easy fix and it works perfect. :cheers:
Troy
This happened to a friend of mines Shee. The idiot that had it before used RED loctite on EVERYTHING, including those tank bolts. As mentioned, cut the heads off, then try to work on it with vicegrips. That way, the only thing your risking is the tank and there are lots of those out there. Luckily for my friend, I had a spare tank.
  • 2 weeks later...
Troy
thanks for the info, if you have a picture that would be awesome
As requested.
Home depot offers these. Works perfect. They do not come with bolts though. Just open a pack while your there and find a few that will fit. It's kind of an odd size thread.
You won't have any in your scrap box so make sure you find a few whlle your there.
Good luck
Troy
