welding crank question
Id say it would be a good thing to weld the crank regaudless of compression!! But on one of my old setups i had 155psi and the crank started to separate rather quickly.. The crank did have pretty many hours on it tho before i bumped the compression!
I would say weld it also but.. I had 190psi in my old setup and ran is for a while never had a problem... although I was always worried about it I just figured if it went I would go with a bigger crank so it would be a win win for me either way!!!
