crank puller/installer for a blaster
guns4children
Guns, do you mean a tool to seperate the cases?i just use a regular puller tool.... similar to the one yama posted, just has 3 slots to put bolts through. could probably rent one at autozone. then when you put it back together yamabond it and tap it together with a rubber mallet SLOWLY!
Edited by 04zSpittinKlotz
GUNS! re-read my post :banghead:
its not hard to put the case back together. ive done 4-5 of them.... separating it would be a problem without a tool . the one im talking about looks very similar to the one paul blart posted but its just a general multi puller tool.
edit: found it http://www.ebay.com/itm/SNAP-ON-BOLT-GRIP-PULLER-SET-CJ2001P-NICE-USED-NO-RESERVE-/271046028317?pt=Motors_Automotive_Tools&hash=item3f1b9a2c1d&vxp=mtr#ht_500wt_1022
this ones going cheap so far. the only special tools you need is a flywheel puller and something like this
