Banshee problems! Please help.
Mack2243
Hi, last week I bought a 99 banshe for 1900 bucks off of kijiji. We got there and the atv ran great. Started first kick and everything. Go it home and it had got a little water in it from the rain on the way. My brothers thought it was the wiring so they started routing through the wiring. Then no go with that so I replaced the stator and the coil and still the same problem; sparks once every 5 kicks or so. Turns out because the ignition has bypassed, my brothers had hooked the wrong two wires together. I hooked it up properly and she fired right up. I had it out yesterday and it was running great. My brother wanted to try it so I killed it and hopped off. He got on, started it, turned around and it died. We thought we fouled a plug so we changed the plugs and still it woulf start right up but bogg down intantly. I openened up the air box and there was a puddle of gas. I cleaned the crabs and now it won't fire at all. I don't know what to do. The TORS has been pulled out. Any info helps. Thanks
Everything in the crabs look to be fine but I just rechecked for spark and it seems that the right cyl has weak spark. And that is the side that's dumping all the raw fuel into the air box.
if the wires were rerouted did you install them back where they would not come apart, or be in the way of the rear shock, or anything that would cause them to come apart during riding ?
Edited by Colby
Hey guys so it was running but now it's not. I rode it to work and it ran great. I was coming home and it would only run good as long as the revs weren't high. So I thought it was just the plugs fouling up so I just kept going. Finally it died right out. No spark or current running through the sysytem not even the lights. When I put a stator in it, I bought it off of eBay for 50 bucks. I don't have the money to put a good stator in it so I went with this one. For 50 bucks I couldn't imagine the quality being great. Could the stator be the problem? Please help. I've electrical problems since day one. I'm almost ready to say fuck it and sell it. Thanks.
