Cases, cylinders, trans, airbox, flywheels, ect
All prices are shipped will have a tracking number. If you need more pics I'm happy to send them. Payments will be sent to jordon_dahl@yahoo.com as a gift or add the 3%. I have good feedback and ship same day or the next day.
Ok here we go,
Set of good cases, I know a crank turns freely in them, there are no studs to mount the cases together( they are in the pics but were just taken out after) includes the shift drum and shift forks-$150 shipped
Set of stock cylinders I believe to be .40 over or 65.00 mm. They were from my motor last year when the Vito's super stock pistons broke. They need to go at least one bore over or maybe two, but good shape and powder coated red. They do not include studs-$150 shipped
2 flywheels- $50 each shipped
Stock bearing carrier-$30 shipped
Stock cdi box from an 01 so it fits 97-06 I believe (could be wrong) -$50 shipped
Stock nerfs/ heel guards. Not sure on the actual name- $40 shipped
Stock head in very good shape- $30 shipped
Stock milled head with pitting on one side, could be ran-$20 shipped
Stock inner hub for clutch with decent fibers, pressure plate, and adjustment screw. Missing most of the bolts and springs-$25 shipped
Stator cover in good shape- $35 shipped
Stock trans includes all gears and a shift shaft, no forks or drum( they are in the cases) it is missing a c clip at the end on one of the shafts- $115 shipped
Stock air box with pro flo adapter, burns from pipes an missing the clips for the cover. I cleaned it for 20 mins but it didn't work too good. A pressure washer would work wonders on it-$60 shipped
Stock clutch cover with water pump, water pump cover, and stock dipstick-$50
Blaster heel guards- $30 shipped
Blaster airbox cover-$15 shipped
Kickstart gear-$25 shipped
Thanks for looking and pm me or text me at 7153141172 if you have any questions.
Jordon
Which of the two flywheels sold? I assume u still have the one with the dark spot on half of it?
Forgot to update the flywheels, they are both sold. Sorry about that
