Main jet Size for 421, with keihn D slide carbs ?
Hey there was wondering if i could get a few opinions or suggestions on what size of main jets i should use with my 421 at sea level, to give me a better idea of where to start and save the troubleshooting. I have Keihn D- Slide Carbs, i think my main jet size right now with the stock .040 bore is 130's, i thought when re-jetting bore size didnt come into play, but i was told when im going with the big bore (404 Vitos) it did, any info would be appeciated. If You need to know what other mods i have done, just give a post thanks - Kevin
from what you have told us i would start out with a 162 mains. I have a 160 mains in my 421cub at sea level & it's still a little on the rich side.
421 cub? serval? 4mill big bore stock cylinder? what are the other mods (pipes, reeds etc)?
i have stock cylinders with the vitos 404 big bore sleeve, with the long rod 4mill crank, Im running V-force Delta 2 reeds, with the pro design manifold system and boost bottle, and Fmf fatty exhaust
