Mattsv8 Posted August 25, 2012 Report Share Posted August 25, 2012 Hey guys i need to rejet my banshee and want help deciding where to start. i have a 05. with stock box, lid with holes in it stock carbs as far as i know carbs are bone stock, had stock pipes and silencers on it but motor is modded. pistons are 65.5 i believe has a 4mil vito crank and ported stock cylinders i knew the stock pipes had to go so i put fmf fattys and power core silencers on im in oh elevation is around 750 to 800 ft. and summer tune is what im looking for i dont wona blow it up on my first ride. so were should i start with jetting. i was tinking going to 260mains. its a twist throttle conversion do know if that matters. i also have 30mm aftermarket carbs for it and a vitos monoblock cyl and 19cc dome head but it only works with a 69mm piston im mostly trails and hills. help me get it going in the right direction. i wana ride it next weekend. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted August 25, 2012 Report Share Posted August 25, 2012 Hey guys i need to rejet my banshee and want help deciding where to start. i have a 05. with stock box, lid with holes in it stock carbs as far as i know carbs are bone stock, had stock pipes and silencers on it but motor is modded. pistons are 65.5 i believe has a 4mil vito crank and ported stock cylinders i knew the stock pipes had to go so i put fmf fattys and power core silencers on im in oh elevation is around 750 to 800 ft. and summer tune is what im looking for i dont wona blow it up on my first ride. so were should i start with jetting. i was tinking going to 260mains. its a twist throttle conversion do know if that matters. i also have 30mm aftermarket carbs for it and a vitos monoblock cyl and 19cc dome head but it only works with a 69mm piston im mostly trails and hills. help me get it going in the right direction. i wana ride it next weekend. I assume your saying you have fattys and stock carbs on now. If so a 330 27.5 pilot 4 clip from the top. Would be pretty close. Quote Link to comment Share on other sites More sharing options...
Mattsv8 Posted September 5, 2012 Author Report Share Posted September 5, 2012 Wow 330s I've read some saying 300s were too much for fattys. What percenage for oil mix. I know more oil leans it and less richens it too. Do u guys go for 30:1 32:1 I think I did it for 32:1. Mine does have a 4 mil stroke kit so I'm shure it wants a little more. Quote Link to comment Share on other sites More sharing options...
Mattsv8 Posted September 6, 2012 Author Report Share Posted September 6, 2012 Wow 330s I've read some saying 300s were too much for fattys. What percenage for oil mix. I know more oil leans it and less richens it too. Do u guys go for 30:1 32:1 I think I did it for 32:1. Mine does have a 4 mil stroke kit so I'm shure it wants a little more. i have a set of keihn pwk 38mm carbs with kan pods. could i use these instead of the stock 28mm. the motor is 4mil stroke and 66.5mm piston. not shure on any aftermarket dome but its a stock head. it had a vitos monoblock cyl and head with 19cc domes and drag pipes setup for drag racing. at that time it had 68.5 mm pisons. right now its just stock cyl head i believe stock compression dome. 66.5mm pistons 4mil stroker short rod. and fmf fattys powercore silencers. stock air box with lid stock single filter. the pwks have pods that fit them and run with no lid. what should i do. right know its lean up top falls flat. Quote Link to comment Share on other sites More sharing options...
Mattsv8 Posted September 6, 2012 Author Report Share Posted September 6, 2012 i have a set of keihn pwk 38mm carbs with kan pods. could i use these instead of the stock 28mm. the motor is 4mil stroke and 66.5mm piston. not shure on any aftermarket dome but its a stock head. it had a vitos monoblock cyl and head with 19cc domes and drag pipes setup for drag racing. at that time it had 68.5 mm pisons. right now its just stock cyl head i believe stock compression dome. 66.5mm pistons 4mil stroker short rod. and fmf fattys powercore silencers. stock air box with lid stock single filter. the pwks have pods that fit them and run with no lid. what should i do. right know its lean up top falls flat. the pwk 38s are 175 main jets and 45 pilot also have a set of 52s. i have all the parts to install these manifolds to pods. if they will work and work better with the fattys id like to use them cause the bigger piston and 4mil stroke. i also have lowering kit and 4" longer swingarm Quote Link to comment Share on other sites More sharing options...
shakar Posted September 6, 2012 Report Share Posted September 6, 2012 if your riding trails, id stick with your stock carbs @ 330m -27 1/2 p like stated above .. big carbs will take some of the low end power .goodluck Quote Link to comment Share on other sites More sharing options...
Mattsv8 Posted September 6, 2012 Author Report Share Posted September 6, 2012 Man that sucks these carbs look sick. The stock ones hd the tors eleminated and are twist throttle. Ill have to pull the stockers off and see what they are inside. I figured the 4mil and slightly more bore would like the pwks. I do a little idle but mostly like hairscramble. Speed and hills. Quote Link to comment Share on other sites More sharing options...
Mattsv8 Posted September 6, 2012 Author Report Share Posted September 6, 2012 Where is the best place to buy the jets and pilot jets? Ill proably need a few diff sizes since I ride in diff weather. Quote Link to comment Share on other sites More sharing options...
Mattsv8 Posted September 9, 2012 Author Report Share Posted September 9, 2012 ok i ordered jets from 290 to 330 and pilot jets from 45 to 47.5 for the stock carbs im proably gona get some 69mm pistons and run the vitos monoblock and head combo with the pwk 38s. what jetting for them would u use. looks like he was lean bad from the pistons that he had with it. the pwk 38s are 175 main jets and 45 pilot also have a set of 52s as they sit now. i was thinking about ordering 10 bigger and get 185s to 190s and use the 52 pilots. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted September 11, 2012 Report Share Posted September 11, 2012 Www.jetsrus.com Quote Link to comment Share on other sites More sharing options...
