dozer Posted August 27, 2012 Report Share Posted August 27, 2012 Everything is spotless. I've gone up and down with the screws. whats your mix ratio? Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted August 27, 2012 Author Report Share Posted August 27, 2012 Castor 927 32:1. Half 110 half pump. Quote Link to comment Share on other sites More sharing options...
Oregon dunner Posted August 28, 2012 Report Share Posted August 28, 2012 Its weird but it whoops some ass against the guys that have richer jetting then mine. I really think its the porting that helps me. HJR did a great job. It seemed to like leaner jetting once I got it ported. I am going to pull the reads and switch them out and try a leaner needle then the CEL. Quote Link to comment Share on other sites More sharing options...
jimbo1986 Posted August 28, 2012 Report Share Posted August 28, 2012 I have a very similar setup as you do 421 serval cpi sb inframes, +4 timing, etc..... Mine also seems to like smaller jets its kinda strange but im using 34mm munkui tm carbs. Still havnt got mine tuned fully but ill let you know what i come up with. Also let me know if u come up with anything else. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted August 28, 2012 Author Report Share Posted August 28, 2012 (edited) Will do. The only guess I can come up with is weak spark. I don't even think its week but who knows. I have a good tested oem stator. I switched to a nology over stock. I have another flywheel comming just in case. I took my whole wire harness apart and soldered any connections and tested all the wires. The only thing left would be a new cdi. From what I've read they don't get weak they just fail. Might try one for piece of mind. I have good compression 164 on both and no leak at all on a leak down test. Maybe the carbs who knows. Maybe porting. Might add another ground as well. Edited August 28, 2012 by 2004LEBanshee Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted August 30, 2012 Report Share Posted August 30, 2012 I'm having a problem with jetting too. I'm running a 4mil serval ported by fast with 22cc domes running race fuel(110) and have 178psi in each cylinder. I have 35mm a/s pwk with 158main and 50pilot. I'm at about 600ft. Haven't had the cover off but believe it was set at +4 timing. Needless to say, I am blowing black ass oil out of everywhere in the exhaust. Any seam hole rivet end cap I mean everywhere. And I'm not taking a little spray, after a couple hours of riding you can actually watch oil drip from the rivets in the silencers. It doesn't run bad, feels like it pulls real good but I had a stock motor with pipes and reeds before this. Oh yeah and I'm running r2 pipes. Do you guys have any idea what it could be? Quote Link to comment Share on other sites More sharing options...
gotta_goatsfast Posted August 30, 2012 Report Share Posted August 30, 2012 I'm having a problem with jetting too. I'm running a 4mil serval ported by fast with 22cc domes running race fuel(110) and have 178psi in each cylinder. I have 35mm a/s pwk with 158main and 50pilot. I'm at about 600ft. Haven't had the cover off but believe it was set at +4 timing. Needless to say, I am blowing black ass oil out of everywhere in the exhaust. Any seam hole rivet end cap I mean everywhere. And I'm not taking a little spray, after a couple hours of riding you can actually watch oil drip from the rivets in the silencers. It doesn't run bad, feels like it pulls real good but I had a stock motor with pipes and reeds before this. Oh yeah and I'm running r2 pipes. Do you guys have any idea what it could be? You are WAY TOO RICH for airstrikers. I run 160 main, 45 pilot, CEL middle clip with my setup (in sig). Air strikers produce a stronger vacuum signal across the main jet circuit, so a smaller main is used. I would start with 150 main, 45 pilot, and CEL on middle clip and jet (probably down) from there. Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted August 30, 2012 Report Share Posted August 30, 2012 Ok I thought it was rich still but didn't know how much. Shit I started at like a 175 main lol. Quote Link to comment Share on other sites More sharing options...
mike0chek Posted August 30, 2012 Report Share Posted August 30, 2012 Ok I thought it was rich still but didn't know how much. Shit I started at like a 175 main lol. those are huge lol, my cub is on 162's but i think it would be still a tad rich on 160's Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 30, 2012 Report Share Posted August 30, 2012 Ok I thought it was rich still but didn't know how much. Shit I started at like a 175 main lol. Yeah, with the A/S pwk's you definitely will end up with way leaner jetting then the guys with regular pwk's. I bet you might be about a 45/48 pilot with a 152 main. God speed on the needle selection with those though. You will be on your own. If you are at Phil's I might have a few different sets you can try Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted August 30, 2012 Report Share Posted August 30, 2012 Yeah, with the A/S pwk's you definitely will end up with way leaner jetting then the guys with regular pwk's. I bet you might be about a 45/48 pilot with a 152 main. God speed on the needle selection with those though. You will be on your own. If you are at Phil's I might have a few different sets you can try Yeah I'll be at Phil's. I'm bringing everything I have for jetting and needles. Maybe you could give me a hand with it. I'm not the greatest at reading plugs. Lol Quote Link to comment Share on other sites More sharing options...
guns4children Posted August 30, 2012 Report Share Posted August 30, 2012 Ok I thought it was rich still but didn't know how much. Shit I started at like a 175 main lol. Damn I also have oil dripping from my rivits. I'm at a 160 main maybe ill try 158. Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted August 30, 2012 Report Share Posted August 30, 2012 Damn I also have oil dripping from my rivits. I'm at a 160 main maybe ill try 158. Yeah starting to wonder how much power I have been missing out on. Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted September 5, 2012 Report Share Posted September 5, 2012 Just an update.... I dropped my main from a 158 to a 155 and it's a complete different machine. Still stoking a lot and blowing oil but not as bad. Didn't have room to do a plug chop on it but will be doing one soon. I think I still might be kinda fat. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 5, 2012 Report Share Posted September 5, 2012 Just an update.... I dropped my main from a 158 to a 155 and it's a complete different machine. Still stoking a lot and blowing oil but not as bad. Didn't have room to do a plug chop on it but will be doing one soon. I think I still might be kinda fat. Next time...probably a good idea to start your own thread, you kinda jacked this one. I had to do a double take/read from the OP to your thread. The OP...your plugs look good to be honest. If you have time, pull the head. See what the piston wash and pattern look like. Quote Link to comment Share on other sites More sharing options...
