cool head torque
what do you torque your noss coolhead nuts to? The 20 ftlbs the factory settings is somewhat of a problem 5 ok 10 ok 15 problem, two of the studs are turning i guess, but will not get tighter, so now what they will not back out, just turn, this is in a new cub cylinder. any help would be appreciated.
You're correct with the 5 10 15 20. But if you have two turning and not tightening, you have to remove them and see what's stripped.
Also you tighten from the centre and work out.
yeah the problem is they won't backout , just my luck fedex fucked it up, finally got new parts start to rebuild the rebuild and now this, WTF!!
are the studs fully seated in the bottom of their holes? cubs are threaded a little deeper than stock jugs for some reason.
Finally got it apart and luckily it was the nut and stud that striped out , not the cylinder. Whew, I thought I had big problems, just ordered new studs and getting new nuts. Don't know if i should get the acorns that stripped out or just get the regular nuts. any thoughts, I know that the acorns won't need siliconed but the regular I've never had strip, so what should i do, what to do, what to do as usual everything has to be a struggle.
Glad you lucked out.
Had a similar problem with my cub and studs also. I lucked out as well, just alot of cussin.
Where did you order your studs from?
Just ordered stock studs from rmatv. the old ones were pretty nasty looking any way still usable but don't look the best. I read that someone on here just didn't screw them in as far and held up fine with blue locktite. This whole build thing is causing me stress, everytime thing start to go well something else goes to shit, but what ya gonna do I'm very impatient about these things. How long does the average build take? I took a basicly stock 96 tore it down to nuts and bolt completely and started ordering parts and off to the powder coat shop, everything but cases, frame, fuel tank (new dual pingel) for it, and wiring harness, stripped the tors wire bull shit off, all else is new. Can anyone say "money, money, moooonnneeeyy" All for something that will probably scare the living shit out of me and park it. I'm too damn old to do shit like this, but gotta have fun building it, and will look good.
Sounds like your getting there. I can relate with your frustration regarding the never ending money drain. Finished my complete rebuild / conversion to drag bike.
Kicked the shit out of my wallet. After my first adventure to the drag strip it was well worth it. :headbang:
Good luck
Troy
Good luck
Troy
Thanks, most times when things go really well there is a problem later, so hopefully the struggle bs is over!
