Anthony Pap Posted August 22, 2012 Report Share Posted August 22, 2012 I just bought a banshee and i had to replace the carbs, i have mods such as trinitty full exhuast, i am runing a 280 main jet and 30 pilot. I am at sea level so the jetting should be correct. The quad wont kick over and will only start when we push start it, then when i have it in neutrol idling its idiling so high that it sounds like someone is reving it when its just siting. Does that mean they need to just be tuned? or could it be the reeds? When i bought the bike with the old carbs the kid had it started 123. Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted August 22, 2012 Report Share Posted August 22, 2012 did you try turning your idle down? also think about checking the float height on those carbs. its always good to check them. while your chicking things do a compression check and be sure those pilot jets are clean as a whistle. Quote Link to comment Share on other sites More sharing options...
joey83 Posted August 22, 2012 Report Share Posted August 22, 2012 Air leak? do a leakdown test. or just shot from the hip and check intake boots. especially where the crossover tube connects. Quote Link to comment Share on other sites More sharing options...
