not good spark but still runs
Pull the plug caps off kick it over, you should see a blue spark from inside the plug cap. Cant tell from OP if you did that or not. If it had a bad spark it would most likely be missing and possibly back firing. Does it bog once you get above 1/4 or so if thats the case i would look at jetting or the main jet could be clogged.
S10 is right also.
Edited by KatyPerry
S10 is right also.
yea just tried that no spark that i can see
Just stick your finger in and grab on to the bars, kick away. Make sure both plugs are out. So the motor spins nice and free. If it tickles then you have weak spark. If your arm goes numb for a second then your pretty close
x2 best way report back with results plz
