kchubb-banshee350 Posted August 22, 2012 Report Share Posted August 22, 2012 So just replaced my plugs and though i would see how good of spark i am getting. i cant see that it is getting good spark. would it still run and idle if i was not getting a good spark?? it has been bogging out alot l. could bad spark have something to do with that ?? Quote Link to comment Share on other sites More sharing options...
S10RACER Posted August 22, 2012 Report Share Posted August 22, 2012 Yes it could still run with weak spark. Quote Link to comment Share on other sites More sharing options...
ClayAiken Posted August 22, 2012 Report Share Posted August 22, 2012 (edited) Pull the plug caps off kick it over, you should see a blue spark from inside the plug cap. Cant tell from OP if you did that or not. If it had a bad spark it would most likely be missing and possibly back firing. Does it bog once you get above 1/4 or so if thats the case i would look at jetting or the main jet could be clogged. S10 is right also. Edited August 22, 2012 by KatyPerry Quote Link to comment Share on other sites More sharing options...
kchubb-banshee350 Posted August 22, 2012 Author Report Share Posted August 22, 2012 Pull the plug caps off kick it over, you should see a blue spark from inside the plug cap. Cant tell from OP if you did that or not. If it had a bad spark it would most likely be missing and possibly back firing. Does it bog once you get above 1/4 or so if thats the case i would look at jetting or the main jet could be clogged. S10 is right also. yea just tried that no spark that i can see Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 22, 2012 Report Share Posted August 22, 2012 yea just tried that no spark that i can see Just stick your finger in and grab on to the bars, kick away. Make sure both plugs are out. So the motor spins nice and free. If it tickles then you have weak spark. If your arm goes numb for a second then your pretty close Quote Link to comment Share on other sites More sharing options...
Finch Posted August 22, 2012 Report Share Posted August 22, 2012 Just stick your finger in and grab on to the bars, kick away. Make sure both plugs are out. So the motor spins nice and free. If it tickles then you have weak spark. If your arm goes numb for a second then your pretty close x2 best way report back with results plz Quote Link to comment Share on other sites More sharing options...
thomas h. Posted August 22, 2012 Report Share Posted August 22, 2012 The check connectors to the coil and clean rust away from coil ground contacts. Quote Link to comment Share on other sites More sharing options...
