Thack82 Posted August 20, 2012 Report Share Posted August 20, 2012 I took my Banshee out on it's Maiden Voyage yesterday to test it out after I put in my new custom made 41/40 Forged Steel 8 Plate Clutch Basket, Clutch Basket Needle Bearing/Forged Kicker Gear (Replaces OEM Kicker Gear and Clutch Basket Bronze Bushing), Mull Racing Shift Detent Bearing Mod, Mull Racing Billet Shift Star, and a Right Side Crankcase Cover Billet Vent Block Off Plate. Everything went great, the Transmission felt tight and precise and it shifted with ease. I noticed I had some form of fluid leaking about a hour into the ride, I checked it out and it was milky looking oil that was blowing out of my Rear Crankcase Vent Tube/Hose. Me and my buddy had noticed that a O-Ring in the Right Side Case was looking pretty rough and I had actually put Orange RTV Silicon on it the last time I had the Right Side Crank Case Cover Off. During the ride coolant was leaking slowly into my Clutch Crankcase oil. I know its the O-Ring that's in that part of the case that's leaking into my oil and overfilling my clutch oil and blowing it out of the rear vent hose. Do any of you guy's know what size O-Ring that is? I Know its most likely metric, is this going to be a Dealer only part? I was hoping I could just pick up a generic Metric O-Ring and replace it. If you guys could help me out with this I would appreciate it. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted August 20, 2012 Report Share Posted August 20, 2012 steel clutch basket? Quote Link to comment Share on other sites More sharing options...
J-Madd Posted August 20, 2012 Report Share Posted August 20, 2012 You can just by a cheap assortment of orings from any autoparts store and find the one that fits. It's not a special oring. BTW Stock clutch setup (billet basket at most) is good for 99% of engines out there, imo. Quote Link to comment Share on other sites More sharing options...
Thack82 Posted August 21, 2012 Author Report Share Posted August 21, 2012 steel clutch basket? Yes Quote Link to comment Share on other sites More sharing options...
