turbosrt4 Posted August 20, 2012 Report Share Posted August 20, 2012 i bought a banshee the right front wheel is cambered out -----leaning out im asumming something is bent the frame is not bent ,how hard is it to bend a spindal Quote Link to comment Share on other sites More sharing options...
5150banshee Posted August 20, 2012 Report Share Posted August 20, 2012 Can also check the tie rod not sure how hard it is to bend a spindle there aluminum or check the mounts also Quote Link to comment Share on other sites More sharing options...
ClayAiken Posted August 20, 2012 Report Share Posted August 20, 2012 Dont bad ball joints cause leaning? Quote Link to comment Share on other sites More sharing options...
turbosrt4 Posted August 20, 2012 Author Report Share Posted August 20, 2012 yea they do buts its not the ball joint Quote Link to comment Share on other sites More sharing options...
Finch Posted August 20, 2012 Report Share Posted August 20, 2012 get a pic Quote Link to comment Share on other sites More sharing options...
jsinar Posted August 20, 2012 Report Share Posted August 20, 2012 If it is bent, I've got a right spindle I'm not using, I bought a pair because I needed a left one.. Quote Link to comment Share on other sites More sharing options...
turbosrt4 Posted August 20, 2012 Author Report Share Posted August 20, 2012 ok ill take a pic today Quote Link to comment Share on other sites More sharing options...
turbosrt4 Posted August 20, 2012 Author Report Share Posted August 20, 2012 here it is Quote Link to comment Share on other sites More sharing options...
turbosrt4 Posted August 20, 2012 Author Report Share Posted August 20, 2012 If it is bent, I've got a right spindle I'm not using, I bought a pair because I needed a left one.. how much Quote Link to comment Share on other sites More sharing options...
jsinar Posted August 21, 2012 Report Share Posted August 21, 2012 $30 shipped sound fair? It almost looks like that lower arm has a little bit of a bow to it..? Before you blame the spindle, pull the hub off and look at the spindle dead on, the shaft should be perfectly square with the spindle itself, On my left side, mine was the opposite, it had negative camber, the shaft was bent up just a little, barely noticible until you got everything put back together.. Quote Link to comment Share on other sites More sharing options...
ClayAiken Posted August 21, 2012 Report Share Posted August 21, 2012 $30 shipped sound fair? It almost looks like that lower arm has a little bit of a bow to it..? Before you blame the spindle, pull the hub off and look at the spindle dead on, the shaft should be perfectly square with the spindle itself, On my left side, mine was the opposite, it had negative camber, the shaft was bent up just a little, barely noticible until you got everything put back together.. That does look like it is bowed not sure maybe were seeing things. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 21, 2012 Report Share Posted August 21, 2012 How are the bushings in the arms? I know they won't make it go out that much, but it doesn't hurt to check them Quote Link to comment Share on other sites More sharing options...
toytech Posted August 21, 2012 Report Share Posted August 21, 2012 here it is it looks like the frame is tweeked where the front lower a arm mounts. could just be the angle of the pic though. Quote Link to comment Share on other sites More sharing options...
turbosrt4 Posted August 21, 2012 Author Report Share Posted August 21, 2012 its the angle Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 22, 2012 Report Share Posted August 22, 2012 It looks like you right spring is compressed more that the left, and the left upper control arm is at a steeper angle than the right. is the right shock stuck compressed? Quote Link to comment Share on other sites More sharing options...
