smoke on left side light to none on right side
ok elvation 0-450 4mill not even seven hours on it 34pjs 48pilots 158mains r2 :1st problem is high idle upon first crank of the day or when ever the bike is cold,now i sprayed the cables to make sure there not sticking didnt work. Second problem upn cranking i notice left side smoke right side dont smoke unless i hit the gas after its warmed up and idle down, carbs are in sync no air leaks around carbs base and manifolds so what you guys think i need to do. please give much needed info thanks guys
idle at the same on both cylinders?
Edited by dunesovertrails
not understanding what your asking high idle upon first crank of the day, after it warms and you tap gas smoke will come out
Lean
Have you checked your reeds??
This is a cubby right?? Stock cast or ported?
nall wacko this is stock cylinders 4mill, bout a month ago i broke a reed petal i changed it but maybe i need to go bck n and check it?
