706DSGB Posted August 19, 2012 Report Share Posted August 19, 2012 I have notice that when I'm in low gears my banshee dont seem like it pulling like it suppose to. I cant even get the front tires off the ground. Im in the powerband but once i hit the high gears it really pulls and you can tell a big difference. 1, 2, and 3 it dont pull right at all but 4 and 5 hold on cause here I come. Also at high rpm it is hard to get it into second gear sometime impossible unless I literally kick the shit out of it into second. Any help would be appreciated. Thank you 1990 Yamaha Banshee Trinity 2 into 1 Setup w/ 35mm Carb FMF Fatty Exhaust System K&N Air Filter w/no lid Wiseco Pistons Bored .40 over Rick Stator stator w/ adjustable timing(+4) Quote Link to comment Share on other sites More sharing options...
ClayAiken Posted August 19, 2012 Report Share Posted August 19, 2012 I have notice that when I'm in low gears my banshee dont seem like it pulling like it suppose to. I cant even get the front tires off the ground. Im in the powerband but once i hit the high gears it really pulls and you can tell a big difference. 1, 2, and 3 it dont pull right at all but 4 and 5 hold on cause here I come. Also at high rpm it is hard to get it into second gear sometime impossible unless I literally kick the shit out of it into second. Any help would be appreciated. Thank you 1990 Yamaha Banshee Trinity 2 into 1 Setup w/ 35mm Carb FMF Fatty Exhaust System K&N Air Filter w/no lid Wiseco Pistons Bored .40 over Rick Stator stator w/ adjustable timing(+4) Either its most likely jetting or your spinning the tires in the low gears and not spinning in the high gears. Quote Link to comment Share on other sites More sharing options...
706DSGB Posted August 19, 2012 Author Report Share Posted August 19, 2012 Either its most likely jetting or your spinning the tires in the low gears and not spinning in the high gears. I just rejetted it casue it was to rich and it was bogging a little. It does spin but I have good tires on it I have Razar 20 x 11 in the rear. They have good traction I dont see that being the problem but it could. If so how can I solve this problem 1990 Yamaha Banshee Trinity 2 into 1 Setup w/ 35mm Carb FMF Fatty Exhaust System K&N Air Filter w/no lid Wiseco Pistons Bored .40 over Rick Stator stator w/ adjustable timing(+4) Quote Link to comment Share on other sites More sharing options...
mike0chek Posted August 19, 2012 Report Share Posted August 19, 2012 dirty air filter?? Quote Link to comment Share on other sites More sharing options...
yzrmbsg Posted August 19, 2012 Report Share Posted August 19, 2012 Rims spinning inside tires..... Quote Link to comment Share on other sites More sharing options...
Finch Posted August 19, 2012 Report Share Posted August 19, 2012 ricky stator not working right Quote Link to comment Share on other sites More sharing options...
Bkm2006 Posted August 19, 2012 Report Share Posted August 19, 2012 clutch slipping? Quote Link to comment Share on other sites More sharing options...
guns4children Posted August 19, 2012 Report Share Posted August 19, 2012 Make sure the carbs open 100% Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted August 20, 2012 Report Share Posted August 20, 2012 I have notice that when I'm in low gears my banshee dont seem like it pulling like it suppose to. I cant even get the front tires off the ground. Im in the powerband but once i hit the high gears it really pulls and you can tell a big difference. 1, 2, and 3 it dont pull right at all but 4 and 5 hold on cause here I come. Also at high rpm it is hard to get it into second gear sometime impossible unless I literally kick the shit out of it into second. Any help would be appreciated. Thank you 1990 Yamaha Banshee Trinity 2 into 1 Setup w/ 35mm Carb FMF Fatty Exhaust System K&N Air Filter w/no lid Wiseco Pistons Bored .40 over Rick Stator stator w/ adjustable timing(+4) Lolol Quote Link to comment Share on other sites More sharing options...
toytech Posted August 20, 2012 Report Share Posted August 20, 2012 I just rejetted it casue it was to rich and it was bogging a little. It does spin but I have good tires on it I have Razar 20 x 11 in the rear. They have good traction I dont see that being the problem but it could. If so how can I solve this problem 1990 Yamaha Banshee Trinity 2 into 1 Setup w/ 35mm Carb FMF Fatty Exhaust System K&N Air Filter w/no lid Wiseco Pistons Bored .40 over Rick Stator stator w/ adjustable timing(+4) razrs don't hook up very good, mine spins them like I'm on ice. Quote Link to comment Share on other sites More sharing options...
BelleauCarl Posted August 20, 2012 Report Share Posted August 20, 2012 +2 on razr dont hook, i first think that my clutch was slipping Sent from my SGH-I997 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
706DSGB Posted August 20, 2012 Author Report Share Posted August 20, 2012 +2 on razr dont hook, i first think that my clutch was slipping Sent from my SGH-I997 using Tapatalk 2 I do have +1.5 in the rear +2 was to wide for the trails I ride. I going to check today and see if the rims are spinning. What are some good tires for the rear in this situation. Tires that have great traction. I currently have (Razor 20x11-10) in the rear. Thanks for everyone suggestions im going to check all these things right now Quote Link to comment Share on other sites More sharing options...
toytech Posted August 20, 2012 Report Share Posted August 20, 2012 I do have +1.5 in the rear +2 was to wide for the trails I ride. I going to check today and see if the rims are spinning. What are some good tires for the rear in this situation. Tires that have great traction. I currently have (Razor 20x11-10) in the rear. Thanks for everyone suggestions im going to chec k all these things right no I cut every other row of tread out, helped a bunch Quote Link to comment Share on other sites More sharing options...
706DSGB Posted August 21, 2012 Author Report Share Posted August 21, 2012 Went out today and checked everything out that y'all suggested and my tires just spend alot. My tires have like 85% thread. So should I try different brand tires or what. Quote Link to comment Share on other sites More sharing options...
S10RACER Posted August 22, 2012 Report Share Posted August 22, 2012 Went out today and checked everything out that y'all suggested and my tires just spend alot. My tires have like 85% thread. So should I try different brand tires or what. cut every other row of tread off the tires. Quote Link to comment Share on other sites More sharing options...
