bansheeboi Posted August 19, 2012 Report Share Posted August 19, 2012 Ok drop the needle second slot from bottom ran better but had a bog on wot. T5 stock carbs 27.5 300 mains still won't idle slight bog Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted August 19, 2012 Report Share Posted August 19, 2012 More info.. Elevation and port work would be a big help. Where was the needle before? Did it run better how it was? Quote Link to comment Share on other sites More sharing options...
bansheeboi Posted August 19, 2012 Author Report Share Posted August 19, 2012 More info.. Elevation and port work would be a big help. Where was the needle before? Did it run better how it was? elvations 0-450 no port work third slot from bottom before, before it ran but it was sluggish on getting up slight tinging check plugs notice is was running a lil lean so i drop needle one slot down to fatten her up, after that she ran better but on wot there was a bog, and on low idle has i would easy on the gas is sounds like she staving for air now Quote Link to comment Share on other sites More sharing options...
Finch Posted August 19, 2012 Report Share Posted August 19, 2012 try a bigger main needle usually doesn't make enough change more for just fine tuning IMO Quote Link to comment Share on other sites More sharing options...
