Replace crank seal
jdog
It's a easier than it sounds. Pull the engine and tear it down. It's like 14 nuts and bolts to split the cases. The top half comes out, the bottom stays with the transmission and crank. I'd get a seal kit and complete gasket kit. You''ll also need gasket maker and I would HIGHLY reccomend getting the book. I'm pretty sure it's even posted on here somewhere. If you can handle a top end rebuild or similiar then you can handle it.
