can anyone in Indy help a brotha out
Whobrey47
got a shee, put the TORS kit on it and its ran like dogshit ever since. had a deal cylinder, wont take throttle worth shit. Carbs are synced, put new plugs in, both cyls have good spark and Im officially tired of fucking with it. I only get to come home one weekend a month so Im lookin to get something done within the next few days.
anyone around here know whatsup with these things I will compensate you for your time and make you sandwiches while you figure it out.
lemme know
took it all apart.
reeds look great.
needles were on 4th clip, moved down to 5th.
unplugged the tors clip and twisted wires together.
still getting good spark.
tightened the caps with channel locks.
cleaned carbs again, sprayed with cleaner then blown out.
Now it wont start.
Under your gas tank on the left side towards the front of the bike.......there is a little black box. Disconnect that black box.....it Is the BRAIN of the TORS unit. Then make sure there is a small black tube n place between the two carbs......there are nipples that this tube goes on.......this is your choke tube.....it uses vacuum pressure to enable the choke on the right carb. They usually refuse to start if you knock this loose or forget to put the choke tube back on.
choke tube is in place and everytime I clean the carbs I completely remove them then take the bowl off and take the jets out and spray em out then blow air thru em. Ill check that black box thing when I get home.
I moved the needles cause someone else suggested it to me. All the thing has done to it is pipes a knn and jetted. I really just wanna pay someone to figure it out I never have time and when I do get to come home the last thing I wanna do is fuck with this thing, if it was running itd be a different story. Anyone got any suggestions
