jdog Posted August 17, 2012 Report Share Posted August 17, 2012 What can make a bike Blowing oil out of the right pipe Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted August 17, 2012 Report Share Posted August 17, 2012 What can make a bike Blowing oil out of the right pipe too much oil in the gas Quote Link to comment Share on other sites More sharing options...
2strokes4u Posted August 17, 2012 Report Share Posted August 17, 2012 What can make a bike Blowing oil out of the right pipe Unburnt oil. Quote Link to comment Share on other sites More sharing options...
quadpro26 Posted August 17, 2012 Report Share Posted August 17, 2012 cases leaking between tranny and crank Quote Link to comment Share on other sites More sharing options...
jdog Posted August 17, 2012 Author Report Share Posted August 17, 2012 It just smokeing out of that one pipe Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted August 17, 2012 Report Share Posted August 17, 2012 It just smokeing out of that one pipe Probably just too much oil in your right side gas tank. Did you check your oil injection bottle to make sure it was full? It's under your seat and has a black cap, and will have a "low" and a "full" line on it. Quote Link to comment Share on other sites More sharing options...
jdog Posted August 17, 2012 Author Report Share Posted August 17, 2012 Probably just too much oil in your right side gas tank. Did you check your oil injection bottle to make sure it was full? It's under your seat and has a black cap, and will have a "low" and a "full" line on it. Do what Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted August 17, 2012 Report Share Posted August 17, 2012 Do what Yeah. Quote Link to comment Share on other sites More sharing options...
cattledog Posted August 17, 2012 Report Share Posted August 17, 2012 ok i am going to save you a little ribbing, first what ratio are you mixing your gas and oil? you may just be useing to much oil. are you useing cheap oil? cheap oil tends to smoke more. it will alway smoke some its a 2 stroke Quote Link to comment Share on other sites More sharing options...
jdog Posted August 17, 2012 Author Report Share Posted August 17, 2012 The oil I use is high performance oil lucas semi-synthetic 2 cycle oil and I mix I 40:1 Quote Link to comment Share on other sites More sharing options...
jdog Posted August 17, 2012 Author Report Share Posted August 17, 2012 ok i am going to save you a little ribbing, first what ratio are you mixing your gas and oil? you may just be useing to much oil. are you useing cheap oil? cheap oil tends to smoke more. it will alway smoke some its a 2 stroke I no its going to smoke but it started all at once it's a thick white smoke Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted August 17, 2012 Report Share Posted August 17, 2012 I no its going to smoke but it started all at once it's a thick white smoke You sure it's smoke and not steam? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 17, 2012 Report Share Posted August 17, 2012 Crank seal Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted August 17, 2012 Report Share Posted August 17, 2012 Probably just too much oil in your right side gas tank. Did you check your oil injection bottle to make sure it was full? It's under your seat and has a black cap, and will have a "low" and a "full" line on it. hate it when that happens Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted August 17, 2012 Report Share Posted August 17, 2012 Probably just too much oil in your right side gas tank. Did you check your oil injection bottle to make sure it was full? It's under your seat and has a black cap, and will have a "low" and a "full" line on it. I hope nobody has actually done that....lol Quote Link to comment Share on other sites More sharing options...
