Trick2stroke Posted August 16, 2012 Report Share Posted August 16, 2012 Stock cylinders mic'ed at 64.5mm on a digital caliper. Plenty of life left in them. 110 shipped. OBO Wave rotor, great shape, straight. 45 shipped. Stock stem clamp, line guides, and clips great shape. 15 shipped NEW 14" K&N filters. 85 shipped. fits 38-42mm carbs Continued... Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted August 16, 2012 Author Report Share Posted August 16, 2012 Not sure what brand these reeds are but they are in great condition and were off a very clean and well maintained bike. Reeds in perfect shape. 25 shipped 40mm Lectron SINGLE carb. Got this with the wild idea I was going to run a 2-1 intake but as my build progressed I went a different direction. okay shape. 50 Shipped. Aluminum hand guards for7/8's bars. 25 shipped. Stock rear brake line alone 10 shipped. Next we have two pairs ofcalipers. All need new pads, pistons are free and fully functional. 35 shippeda piece. Complete front spindle,hub, caliper set. Calipers have good pads and are fully functional. Hubs havegood bearings, ready to bolt to your a arms and go. 100 shipped. Three (3) sets of radiatorhoses in good shape, no dry rot, tears, or anything. 20 shipped a peice.Radiator in good shape, no cracks or leaks, some bent fins, 30 shipped. 40shipped for one set of hoses and radiator together. Stock swinger/carrier.Straight, no issues, good needle bearings and good carrier bearings, taken offa very clean and well maintained bike. 120 shipped. Stock skid plate, decentshape, has plastic chain slider. 20 shipped. Stock carrier could usenew bearings. 35 shipped. extra chain guide, free with purchase of anythinglisted. Continued... Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted August 16, 2012 Author Report Share Posted August 16, 2012 Two stock heads, appear tohave had deto. 20 shipped a peice. One set of stock footpegs, one set will require spacers as the right peg has a straight mount. Stock stator plate in goodshape. 10 shipped. Stock rear shock, OK shape, no leaks but it could use new bushings. 40 shipped. Two stock tail lights. All were working but again they have been sitting for a long time and I have not tested them since. 10 shipped a piece. OLD style spindles/calipers. 87-90. One caliper the bleeder snapped off on disassembly. Everything else is fine, they were sand blasted and painted for a resto project then replaced with the newer style after the bleeder snapped. Maybe good to have a clean set of spares for you guys with an older bike. 40 shipped. Stock clutch covers. Both in good shape, could use a good cleaning, probably a kicker seal to be safe. Water pumps and impellers are in good working order. 45 shipped a piece. Stock clutch insert free with any purchase. Stock stator covers in decent shape. One has been cut for easier front sprocket access. 20 shipped a piece. First buyer gets the one rubber gasket I have. continued... Quote Link to comment Share on other sites More sharing options...
sandman125 Posted August 16, 2012 Report Share Posted August 16, 2012 I'll take one tail light give me your PayPal Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted August 16, 2012 Author Report Share Posted August 16, 2012 Two sprocket hubs, one PC'ed purple w/ good used 41T sprocket. 15 shipped for plain one 20 shipped for sprocket/pc'ed.. One disk hub PC'ed blue. 15 shipped. All splines in good shape. Slightly bent stock bars. 15 shipped. Stock cages with good boysen reeds. 25 shipped. Aluminum reed spacers. 10 shipped. Stock water pump impeller, cover, and water pump clutch cover. All good shape. 20 shipped. Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted August 16, 2012 Author Report Share Posted August 16, 2012 That's most of it I think. Due to the horrendous amount of pictures I tried to keep it to a minimum to illustrate each part. If you need/want more detailed pics of something specific that's no problem, let me know. Also may have left out some details here and there, again, if interested in something and need more info shoot me a PM or email (trick2stroke@yahoo.com). Also have 250R parts but I'll save that for another time. If you have interest in the 250R stuff just ask me and I can give you a list. Thanks, Blake Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 16, 2012 Report Share Posted August 16, 2012 Did you ride that cut trans? Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted August 16, 2012 Author Report Share Posted August 16, 2012 I myself did not, it came as part of the cases that are listed and was run on a cub. I haven't used many of those parts, they are take offs and parts that have laid around for a while from bikes or motors that have come and gone. That's why I am listing some parts cheap because I have not tested them. I will post more detailed pics or gather more detailed info on a certain part if you need. This is just a catch all listing of the stuff I pulled out. These prices are negotiable, to a reasonable extent of course. If anyone was local I'd cut some killer deals to clear this out without shipping. Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted August 17, 2012 Author Report Share Posted August 17, 2012 Added a few more pics. Bump. Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted August 17, 2012 Report Share Posted August 17, 2012 sent me your PayPal info I'll take a set of rears hubs, the ones at the right side of the picture (gold in color) Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted August 17, 2012 Author Report Share Posted August 17, 2012 One tail light - SOLD. Cut trans/forks & stock cages/carbon reeds - SOLD. Rear brake assembly, gold rear hubs, stock skid, clutch cover(oem insert), kicker, and pegs that do not require spacers - SOLD. Anything bought within the next 1.5-2 hours will ship today. Quote Link to comment Share on other sites More sharing options...
camatv Posted August 17, 2012 Report Share Posted August 17, 2012 sent PM also wanted to add if your even thinking of building a RZ banshee this setup is as complete as they get. its a great deal with all the electroncis that are updated. with that controller you can adjust how and when the PV's open according to RPM and that makes a HUGE difference in the way the power comes on. i think you can also add a TPS to it and it will run the pv's according to load and rpm inputs. the cylinders have a nice port job on them nothing to crazy. if i had more time i would consider buying all this and just playing around with the set up. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted August 17, 2012 Report Share Posted August 17, 2012 What size carb do those filters fit? Thanks! Quote Link to comment Share on other sites More sharing options...
robert0762 Posted August 17, 2012 Report Share Posted August 17, 2012 (edited) I'll take stator and flywheel send paypal Edited August 17, 2012 by robert0762 Quote Link to comment Share on other sites More sharing options...
gwinnraptor Posted August 17, 2012 Report Share Posted August 17, 2012 Ill take a set of intake boots if theyre good. PM me your paypal. Quote Link to comment Share on other sites More sharing options...
