tristan Posted August 16, 2012 Report Share Posted August 16, 2012 Installed a mull water impeller and billet gear but the impeller rubs the housing bad and their is alot of play back and forth and yes i installed it right checked and re checked please help dont believe it should be like this. Thanks Quote Link to comment Share on other sites More sharing options...
tristan Posted August 16, 2012 Author Report Share Posted August 16, 2012 Anybody im cant be the only one that has had this problem Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 16, 2012 Report Share Posted August 16, 2012 Did you replace the seal? And wait more then 20 minutes for a response. It's late and past a lot of people's bed times. I just sneak back to the computer Quote Link to comment Share on other sites More sharing options...
tristan Posted August 16, 2012 Author Report Share Posted August 16, 2012 Yes new seal but u would not think that would matter Quote Link to comment Share on other sites More sharing options...
bansheeboie Posted August 16, 2012 Report Share Posted August 16, 2012 Pro design billet impeller, FTW!! Lol Are u sure it's fully seated in? Quote Link to comment Share on other sites More sharing options...
tristan Posted August 16, 2012 Author Report Share Posted August 16, 2012 Yes it seated its almost like where the impeller meets the seal is to short on the impeller its self i was going to go with the pro designs but someone said just get it from mull when i got the gear so i did now im having this problem. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 16, 2012 Report Share Posted August 16, 2012 How's the bearing? Quote Link to comment Share on other sites More sharing options...
tristan Posted August 16, 2012 Author Report Share Posted August 16, 2012 Good to Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 16, 2012 Report Share Posted August 16, 2012 You got the pin lined up? Did you try to tap it with a rubber mallet to see if you can get a little more room out of it? Quote Link to comment Share on other sites More sharing options...
tristan Posted August 16, 2012 Author Report Share Posted August 16, 2012 Their is alot of play alot more than the seal could help i believe pin is in ever thing is right but the play in the impeller Quote Link to comment Share on other sites More sharing options...
shakar Posted August 16, 2012 Report Share Posted August 16, 2012 (edited) after you slip the impeler in , it goes pin then gear ,washer and c clip.did you put the washer on? goodluck Edited August 16, 2012 by shakar Quote Link to comment Share on other sites More sharing options...
blowit Posted August 16, 2012 Report Share Posted August 16, 2012 Guys, I am involved right now and will work through the issue with him. I am still not quite sure what the "play" is but I believe this is in reference to the axial or push/pull play in the impeller with the pump cover off. They all move a bit in that respect but never the less, we will get it figured out and get him going. I am still not sure what is going on. Quote Link to comment Share on other sites More sharing options...
