Clutch side coolant tube bent?
I was wondering why the hell my clutch cover didn't wanna come off come to find out this coolant tube looks bent. I was wondering if you can pull this tube right out and if there's an o ring or something there, or if I have to split the cases? I could also try to just carefully bend it straight, it trashed the old o ring that was there also. Thanks.
looks ok to me. I put liquid teflon on the oring and tube, helps prevent corrosion and cover goes on and comes off much easier.
looks to me its fine, once you seat it back to the retainer clip it will be straight. just looks like it pulled inward when you pulled the clutch cover off. Push it back towards the carbs against the clip and see if it looks right.
Chris
Your cover was difficult to remove because someone put a giant fucking o-ring on there. LOL Get the yamaha O-ring thats supposed to go on the tube, push the tube back towards the center of your case until it bottoms out on the little snap-ring, and your cover will go on / come off a lot easier!
-Jared
